Old 09-26-2012   #1
vish
vish's Avatar
Drives: 95 tsi
A/M conversion problem with the wiring.
95 talon tsi awd
got my Auto to manual conversion finished, if any one could help with a step by step for the wiring would be much appreciated the car wont start..... all im thinking of is the neutral safety switch but i can seem to locate that either. all i have done is disconnected the TCU. or should it be connected? also do i need to replace my ECM with the manual one? thanks again.
-vish
vish is offline   Reply With Quote
Old 09-27-2012   #2
vish
vish's Avatar
Drives: 95 tsi
Re: A/M conversion problem with the wiring.
any one is having this problem or is going to run into this problem. The big plug going to your shift selector has the two wires you need to splice together. One will be an 18g wire that's black with a red stripe and the other will be a 18g solid black wire. Hope this helps some one.....
Old 09-28-2012   #3
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
im pretty sure if you get a 5 speed ecu and wire harness the car will run.
Old 09-29-2012   #4
vish
vish's Avatar
Drives: 95 tsi
This way you don't need to get a 5speed wiring harness or ecu....
Old 09-29-2012   #5
i swapped a 5spd ecu in mine and it runs fine? I dont think it matters if its auto or not. I can take a pic of my harness if you like at my shifter or whatever
