Old 10-18-2012   #1
Trogdor
Trogdor's Avatar
Drives: people crazy
Going to battle it out with Mitsubishi
So, they're going to try and deny my warranty claim. Here's the full background.
While on the cruise I threw an SES light: p0302 cylinder #2 misfire. Schiedes reset the ECU to clear the code. It came on again (later found out it was P0300 random/multiple misfires). The car seamed fine in 1st-4th. But when I got in to 5th and started to accelerate it would shudder. I could drive it in 5th fine, but couldn't really get on it.
This was probably 30 miles from the hotel when all this happened. Drove it there just fine, staying off the accelerator. On the way home the next day, the rod blew, in 5th gear at about 60-65 mph.
Somewhere on one of the computers (not the ECU) it says the car over revved. The OEM rev limiter in the car is 7599 (redline is 7000). The car over revved to ~7900PRMs.
Being that the car is totally stock, Mitsu is trying to deny my claim based on this over rev. What I'm wondering is how the connection from an over rev could (if at all) lead to a blown rod. Over rev should in theory either spin a bearing or damage the valvetrain, right? Either of those could lead to a busted rod. But I want to see either of those or something else in between is actually the case before they try to deny it, cuz it feels like they're jumping from A to C with out knowing what's in between.
Also, how did it over rev in the first place? I could see if it was at high RPMs and I down shifted several gears and the engine continued to roll on. But that's not the case here.
Or, am I totally wrong and simply the over rev and directly cause the blown rod?
Old 10-18-2012   #2
shurikss
shurikss's Avatar
Re: Going to battle it out with Mitsubishi
If your car rev limiter at 7599 , no way you can rev up to 7900 , unless you down shift in high rpms then you can record 7900.
shurikss is offline   Reply With Quote
Old 10-18-2012   #3
Trogdor
Trogdor's Avatar
This is what I thought too.
Old 10-18-2012   #4
shurikss
shurikss's Avatar
Good luck with battle !!!
Old 10-18-2012   #5
Is there anytime that you went over the stock redline?
Old 10-18-2012   #6
It could potentially weaken it to the point of failure depending on exactly how the rod failed. I highly doubt it though, DSM factory rods and pistons have gone way higher than that repeatedly, something else is wrong here.
Old 10-18-2012   #7
This is an X remember...not a 6-bolt
Old 10-18-2012   #8
Revs, high torque load....any sharp, sudden change could lead to problems...theoretically.
I've rev'd both of my evos to 8000 though, that's really not much of an over-rev.
Old 10-18-2012   #9
93gtpeater
Drives: cbr 1000rr repsol
Good luck on getting a new motor.
Old 10-18-2012   #10
I have a real hard time believing you can throw a rod on those things by running 500rpm over the factory fuel cut.
The factor of safety used to design the rotating assembly is usually enough to accommodate all sorts of unforseen load factors, because its easier to overdesign something than it is to constantly fix it under warranty.
Maybe you had a slightly defective rod from the factory and over time it fatigued and failed.
Old 10-18-2012   #11
Trogdor
Trogdor's Avatar
So, I guess the first thing is: is it even possible to over rev it in neutral?
Old 10-18-2012   #12
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
You can misshift and over rev as well, free revving essentially.
Ask me how I know
Old 10-18-2012   #13
10EVO
10EVO's Avatar
Drives: 2008 EVO GSR
Ask me how I know
Oh boy haha how??
2008 Mitsubishi GSR
Installed:18x10.5" Work CR-Ultimate wheels, D2 Racing Coilovers, HKS Hi-Power Catback Exhaust, CPE Gauge Pod, Kenwood Double Din Head Unit, MTX Amp, AEM Oil, Boost, and AFR Digital Gauges, and Electronic Boost Controller
10EVO is offline   Reply With Quote
Old 10-18-2012   #14
Murlo26
Murlo26's Avatar
Originally Posted by 10EVO View Post
Oh boy haha how??
Over 9000 when I was getting clutch lockout at the track
Old 10-18-2012   #15
10EVO
10EVO's Avatar
Damn!!!!!!!!!
2008 Mitsubishi GSR
Old 10-19-2012   #16
Time to back out of that lease.
Old 10-19-2012   #17
Trogdor
Trogdor's Avatar
So sounds like it is possible for it to rev past the rev limiter.
The next question is what actual damage does that cause? Things like a spun bearing, floating a valve... What else could an over rev directly cause.
Old 10-19-2012   #18
Didn't you say you missed a gear and grabbed another by accident? That would be a mechanical over-rev, no rev-limiter can stop that.
My theory is that the over-rev damaged a spark plug and then the damaged spark plug caused some crazy detonation damaging the rod.
Old 10-19-2012   #19
How would the over-rev damage a spark plug?
I could see if it had been missing a lot (the multiple miss fire codes) that the rod could have been taking a beating the whole time it was missing trying to do pulls then just randomly let go. I threw a rod on my old celica just doing 75/80 down the highway when it was full of oil.
Were you getting on it at all when it let go?
I agree that I don't really see how one over-rev could make a rod shoot threw the block 50 miles later, especially only 500rpm over-rev.
Good luck!!
Old 10-23-2012   #20
Not so much the over-rev, but the detonation of bouncing off the rev-limiter. The X plugs are much more fragile than anything the DSM/8/9's ever had to deal with, probably due to the smaller size; a lot of us have had a spark plug failure in one form or another.
