Old 11-14-2012   #1
Yiddie
Yiddie's Avatar
Drives: 98GSX
My New 98 gsx build
Alright I need some suggestions on what kind of turbo to use on my new setup..
MAP stage2 shortblock
Built 2g head
Debating between a magnus/jm fab intake mani
Fuel setup for e85, thinking for injectors, fic 2150s
I currently have a new fp race manifold, My question is should I get the precision 5857 ball bearing n use the manifold, Or get a tubular and get a different turbo? Maybe a 6266?
Old 11-14-2012   #2
Re: My New 98 gsx build
What are you goals?
how fast do you want to go?
budget?
Old 11-14-2012   #3
Yiddie
Yiddie's Avatar
Drives: 98GSX
Tight Budget why I'm debating on a tubular(which one if I do)
Either way I need a new turbo
My power goals are kinda open right now, I guess anything past 500 i'm happy with.
But yea know if keeping that mani makes it very limited then I'll have to make it work by getting a tubular I suppose.
Old 11-14-2012   #4
meh, all the new tech makes it easier to make power.
The FP is the best mitsu flanged turbo manifold out, a 5858 should get your goal but the 6266 will do it really easy.
But if you are on a tight budget, you don't need 1/2 the stuff you listed. You could spray it.....
Old 11-14-2012   #5
Yiddie
Yiddie's Avatar
Drives: 98GSX
What could the 5858 ball bearing with that mani get me for power?
What do you recommend for a tubular? I was looking at the map one.. Sooo nice haha but also like 1300$..
magnus or jm fab for intake?
I kinda look at it as... If i'm gonna have a built engine don't really wanna cut any corners, Want it to be legit. I know I really should get a tubular it would be worth it in the long run.. I just thought if that fp mani would work i'd use it, But thinking about it.. if I ever did switch to a tubular I'd have to get another turbo, sounds more expensive in the long run.
Old 11-14-2012   #6
I'm confused you seem determined for a tubular manifold, why?
Old 11-14-2012   #7
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
I'd go with JMF for the intake manifold unless you're going with the cast Magnus . The regular Magnus SMIMs are garbage they crack all the time I've personally had 2 of em crack on the runner.
As far as a manifold I'd stay with the fp if your funds are low since there's plenty of mitsu flanged turbos that'll get you to your goal HP.
notsostockgalant is offline   Reply With Quote
Old 11-14-2012   #8
Yiddie
Yiddie's Avatar
Drives: 98GSX
Yeah.. I think I'm just gonna keep the manifold and get a 5858 or a 5857.
Or with that setup which turbo you think would be best? I'm open for suggestions
Old 11-14-2012   #9
with that much power, i'd be worried about the transmission...unless you have a built or rebuilt one already.
i'd vote the 5858 but the 6266 is the route i would go if i went that way.
Old 11-15-2012   #10
Yiddie
Yiddie's Avatar
Drives: 98GSX
Yeah I'm thinking the jm fab drag intake and the 5858 ball bearing.
That's my next step on this build.. I still have a stock tranny, besides a act street disk clutch installed.
Since the engine/tranny are out of the car I should probably do something about that. Any suggestions? haha
Old 11-15-2012   #11
twin disk and let her buck.
Old 11-15-2012   #12
EVOJ
Yep!!! She Goes
EVOJ's Avatar
Drives: 03 EVO VIII
I had a OBX Racing tubular manifold on my gst made good powa and actually did it job making good torque. People had their doubts about it but she held. My take on tubular manifolds are you get what you pay for, so beware.
You know its true
EVOJ is offline   Reply With Quote
Old 11-15-2012   #13
500hp dynojet? Could do that fairly cheap if you just be smart about your parts and keep it simple.
Keep the FP exhaust mani, old school bolt-on SCM61 internally gated, fmic, twin 255hp's, 1600 injectors, DSMLink, stock 6 bolt motor/head, cheapest used set of used cams. 25psi and you're probably at 500+ on a dynojet.
Old 11-15-2012   #14
EVOJ
Yep!!! She Goes
EVOJ's Avatar
Drives: 03 EVO VIII
^ So agreed, by far the best reliable cheapest way to make good powa
You know its true
Old 11-15-2012   #15
Yiddie
Yiddie's Avatar
Drives: 98GSX
These are the mods that I have done already..
ETS FMIC
E16G
FP Race Manifold
Turbosmart dual port bov
FIC 950s
ss o2housing
E85 tuned(29psi)
ACT street disk clutch
I sold my exhaust, head, o2housing already, Selling the 16g also
Either way I'm putting a built 6bolt in with a built 2G head.
Probably a DW300 fuel pump.
I'm not aiming for a certain number, Whatever those new mods will give me what I'm looking for.
Old 11-15-2012   #16
b00sted_spyder
Can't go wrong with a Billet wheel HX35 with Mitsu hot side for a budget turbo.
Teaser video
http://www.youtube.com/watch?v=h_LkbIKBTu0
Old 11-20-2012   #17
Tachyon
Tachyon's Avatar
Drives: Icarus
Teaser video
That had to have been the slowest 500 hp car I've ever seen.
What are your actual goals with the car? Not having a defined goal often times leads to an over-turbo'd, over-manifolded lag-fest that a good 16g setup would eat for lunch, and be a lot more fun to drive.
It sounds like you're building a street car, but is there a specific 1/4 time or trap speed you are shooting for?
-Sebastian Vettel
Old 11-15-2012   #18
So you're not aiming for a certain number? And you want us to tell you which turbo/manifold setup to go with? A JMF Drag intake manifold on a 58mm turbo?
Old 11-15-2012   #19
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Why do you need a drag mani on a 500hp car. It will probably do more bad than good.
The DW300 is not much more than the 255 so I'd go with the new walbro 450 pump. Should easily get you there.
If you have an account on tuners look up people's setups in the 400-500 range and make a parts list.
There's a million parts to get ya there, just depends on how much boost you wanna run/ and how much $$$ you wanna spend.
Old 11-15-2012   #20
:facepalm:
