Old 01-30-2013   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
this looks to good to be true, has it been proven?
https://www.youtube.com/watch?v=uTeH...e_gdata_player
for big turbos this sounds like it would be nice, im not familiar with intakes at all. are there better options , that still give good low end ?
but you know what they say "just one more moving part to break" (has anyone ran this setup?)
just looking for options on the rebuild.
M1L3S is offline   Reply With Quote
Old 01-30-2013   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: this looks to good to be true, has it been proven?
thats pretty sweet, dsms forever evolving!!
2006 WW IX RS 396/404 - SOLD
Old 01-30-2013   #3
I was going to run one of those years ago on my 2G but opted out. End of the day once you are making decent power, this is a restriction and it'd have to go bye-bye anyways
Old 01-30-2013   #4
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
I've always been curious about these. They seem to be a little too expensive as everyone wants gold for them. I can understand why though. It would probably be decent on a 16g or equivalent car.
Old 01-30-2013   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
They work well.
Here's a dyno of a 16g gas setup from 2007:
Blue line is the Cyclone, red is a 1G Stock manifold.
The record for max power on a Cyclone was 621 HP on a DJ using a laggy GT-35:
I suspect like scheides said, it would be a restriction on high-flow setups, but I have absolute data from back-to-back runs with the same setup.
-Sebastian Vettel
Old 01-30-2013   #6
M1L3S
M1L3S's Avatar
Drives: 99Gst
They work well.
so for a 2.3 hx40 build , wanting 500ish do you think it would be a benefit or a restriction?
ive read that it out flows a 1g , but not by much.
seeing how my engine is already a 2.3 I figured the cyclone would give even more grunt in the low end before boost steps in.
Old 01-30-2013   #7
blackrosenova400
blackrosenova400's Avatar
Im running a cyclone intake on my 2.3 with an actuator just like in the video. Automatic with stock cams and a bastard 20g at 32-35 psi. It is a nut case out of the hole.
Im also going to further the actuator setup by adding a boost control solenoid and controlling it with my evo 8 ecu so that it only opens the butterflys at 4000 rpm.
20g Mafia
Old 01-30-2013   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
With an HX-40 I would use a SMIM over the Cyclone because the turbo can supply sufficient airflow that it makes sense to make the engine more efficient in the upper RPM range.
-Sebastian Vettel
Old 01-30-2013   #9
blackrosenova400
I agree, it would not be a good choice for comparing it to a smim for 1/4 mile drag racing and overall power. But for a fun street car, and maybe the 1/8th mile, I like it!
20g Mafia
Old 01-30-2013   #10
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Can I join friendly peak torque battle? Or is it for 1g's only?
Old 01-30-2013   #11
Tachyon
Tachyon's Avatar
Drives: Icarus
Sure but you'd be basically bringing a gun to a knife fight :P
-Sebastian Vettel
Old 01-30-2013   #12
Murlo26
Murlo26's Avatar
I thoughts yours wasn't too far off mine at the last dyno day? You just started spewing fluid and didn't get to crank it up.
Old 01-30-2013   #13
TD05H vs. EF4 !
Old 01-30-2013   #14
TD05H vs. EF4 !
That sounds totally fair!!
Old 01-30-2013   #15
b00sted_spyder
There is a member on here with a black 2gb talon that has one of these manifold. I forgot his name but he's pushing over 500hp. I remembered him posting his car for sale on here. Really nice dude and clean car!
Old 01-30-2013   #16
b00sted_spyder
Found his car for sale here:
http://mitsustyle.com/forums/showthread.php?t=30003
Old 01-30-2013   #17
polishmafia
Smells like cat poop
polishmafia's Avatar
I clicked this thread hoping we were going to talk about this...
