Old 02-18-2013   #1
4seasons69
4seasons69's Avatar
How much amperage should twin fuel pumps pull?
I got my car running yesterday and it's popping the 40amp maxi fuse for the fuel pumps. We put a 50amp in that we had laying around and it ran fine.
The pumps are twin walbro 310lph pumps (Ford gt pumps) with a single power feed. The things I changed this winter is I rewired the sending unit with 10 gauge wire and replaced the strainers on the pumps. I did not use the same strainers that were on there. I used ones that a lot of people on the Ford forums say work well with these pumps and they were in Stock at a local parts store.
Are the new strainers just making the pumps work harder, is it the bigger wiring?
Should I just rock a 50amp fuse or figure out why these pumps are now blowing the fuse. Any input and advice is greatly appreciated!
Old 02-18-2013   #2
Re: How much amperage should twin fuel pumps pull?
http://www.autoperformanceengineerin...l/fpspecs.html
Are they wired in series or parallel?
That link above doesn't show your pump, but it shows their smaller pumps expected amperage draw to at least give you a little bit of an idea.
Old 02-18-2013   #3
4seasons69
4seasons69's Avatar
Should be parallel. They have one power feed that splits into two wires. One for each pump. Then they each have their own ground
Old 02-18-2013   #4
10 gauge wire is pretty small for 2 pumps to run off of. It is fine for a single pump. I would double check all the connections and also put a volt meter on them to see what the voltage is at the pump. Something must be messed up in the wiring to pop a 40 amp fuse, especially at idle.
Old 02-18-2013   #5
4seasons69
4seasons69's Avatar
10 gauge is small? They were running on 14gauge before and never blew fuses. I will double check all connections. And will double check the voltage at the pumps.
Old 02-18-2013   #6
4seasons69
4seasons69's Avatar
Yeah I agree 40 seems excessive. The alternator was putting out about 14.2 v yesterday
Old 02-18-2013   #7
So according to my link, a 255hp at 13.5V at a base pressure around 45psi, you'd expect about an 8A draw. If you have them wired in parallel, then I'd expect around 16A total draw.
Your pump is different, but still I don't think you should be popping a 40A fuse.
Old 02-18-2013   #8
Do you have the pumps clamped side by side or do you have a spacer between them?
Old 02-18-2013   #9
4seasons69
4seasons69's Avatar
You know what I'm pretty sure they are side by side with no spacer between them
Edit: I just checked a picture I took of the sending unit when it was out and the pumps are touching. You think that could be the culprit?
Old 02-19-2013   #10
I have heard of thr electrical current or whatever of 2 pumps right next to eachother fighting eachother so some people have added a simple spacer of some sort beteeen the two. Im not sure if you would just use a rubber or aluminum or what but i think it obly nrrds to be a quarter to half incg thich piece.
Old 02-19-2013   #11
4seasons69
4seasons69's Avatar
I guess that kind of makes sense. Next time I'm working on the car ill figure something out for a spacer and see if that helps
Old 02-19-2013   #12
blackawdtsi
Drives: 2G DSM
Don't use rubber if you run e85.
Old 02-19-2013   #13
4seasons69
4seasons69's Avatar
Why not? Even if it's fuel line? There are already rubber hoses in the tank that connect the pumps to the sending unit
Old 02-19-2013   #14
Fuel lines are not made of real rubber.
Old 02-19-2013   #15
4seasons69
4seasons69's Avatar
Okay cool.
Old 02-19-2013   #16
I would just use a small piece of fuel line and slice it open, slide it in between the pumps, then tighten the clamp back up.
Old 02-19-2013   #17
There is special submersible fuel line for inside fuel tanks. Most fuel lines can not tolerate fuel on the outside of them and will break down.
Old 02-19-2013   #18
4seasons69
4seasons69's Avatar
This is the plan right now. Hopefully this will take care of the problem.
I forgot about this. I will make sure I get some that is submersible
