Old 03-19-2013   #1
LingLing
AznKraut
LingLing's Avatar
Project Slowbaru
Well here goes nothing. Fellas, there’s other way to say it…
I bought a Subaru.
Here’s the skinny skinny. It's a '98 Legacy GT.
The motor has been swapped with a hybrid consisting of an EJ22T shortblock (Subaru’s only closed deck block to date.) This block comes out of a 90's turbo Legacy. The rotating assembly consists of stock EJ22T pistons, STi rods (Nearly identical in size, just beefier than the EJ22T rods), and an EJ22T crank to keep the stroke (75mm) the same. Up top…I mean, on each side are stock rebuilt DOHC N/A EJ25 heads. These are a huge upgrade from the SOHC 2.2 heads that came from the factory. They're not going to net me HUGE hp gains, but they should help low end torque and top end flow. Intake manifold and TB is off a WRX.
For a turbo I'll be using a JDM twin scroll VF37 that comes stock on the JDM STi. I really don't know too much about these to be honest. From the people I've talked to, it'll spool quicker, and hold top end power better than a 16g. I've read through multiple build threads with people making around 300awhp with these. Perfect for my current power goals.
For fuel, I am planning using stock STi injectors, an adjustable rising rate FPR, with a 255 in the tank. Nothing serious, because at this point it doesn't need to be. They've been sitting in my garage since last year, and I'm sure the nozzles have collected dust inside them. So before I use them I think I'm going to have them cleaned, and flow tested. Flow should be right around 560cc at stock fuel pressure. (Self note: Rising rate FPR inceases at a rate of 1:1)
I’ll be tuning with Opensource on an ’03 WRX ECU. This will allow me to tune, and flash my ECU via laptop. No real reason for using this other than it seemed like the most cost-effective option, and many people have had great success with it.
It’s a 5-speed, but it’s a trans from an Outback. Shifting involves more searching and hoping, rather than rowing through the gears. That coupled with eco-gears and no aftermarket support means I’m working on sourcing a late model WRX 5-Speed. Ultimately meaning I’ll have to change from a cable to hydraulic clutch setup, but it will open up more aftermarket support. To give you a sense of how tall my gearing is, my final drive is 4.11. Redwood tall gearing FTL! Once I find a transmission it will get upgraded (Maybe even with a few PPG gears) to handle future modifications.
In the future, I think I want to build this in to something I could potentially road race (Gutted, relocated fuel cell etc..). There's definitely another motor in store for this thing. But, I haven't thought much about what that build will entail. Most likely something around double the power of my current goal of 250awhp.
Having the ability to use 02-03 WRX suspension components I have tons of choices for suspension. Haven't decided on what, since the stock WRX suspension installed works just fine. It gives the car a pretty good stance for stock components. I'm using WRX hubs as well, giving me the same brake upgrade choices as any WRX owner. I think it's pretty sweet to be able to use late model parts on a car 15 years old! The car needs brake attention badly. The pedal is very soft. So once spring time rolls around I'll throw on SS lines, and possibly upgrade to STi calipers with an aftermarket street pad.
Current setup as of 4/1/2013
-EJ22T block
-EJ22T crank
-STi rods
-EJ22T pistons
-EJ22E head gaskets
-EJ205 heads
-EJ205 cams and valvetrain
-EJ205 intake manifold
-Side feed TGV deletes
-EJ205 throttle body
-STi yellow side feed injectors
-Walboro 255
-VF37 twin scroll setup
-'06 WRX TMIC
-TiAL bov
-Catless twin scroll up pipe
-Catless downpipe
-3" exhaust
-Grimmspeed 3-port BCS
-AEM UEGO wideband
-Rom Raider tune
-'03 WRX ECU
-'03 WRX gauge cluster with '04 WRX bezel
-WRX power steering pump/lines/reservoir
-WRX alternator
-Battery relocated to trunk
-'01 Outback 5-Speed transmission
-4.11 rear differential
-Short shifter
-WRX flywheel (Possibly going with a lightened flywheel)
-Clutch undecided
-WRX clutch and brake pedal assembly
-WRX front subframe
-WRX crossmember
-WRX hubs
-WRX axles
-WRX suspension
-WRX control arms
-JDM 1-piece projector headlights
-Rusty green body
-Stock Legacy GT wheels
-3 flat snow tires
Now, for what’s going on below.
For me to be able to tune with Opensource I need to run a WRX ECU. What I have to do is remove the engine related wiring of the WRX harness and merge it with the rest of my Legacy harness. It sounds like a mess, and honestly it can be. But I don’t see why people refuse to try it. Once you isolate the different parts of the harness you need you remove everything else. The pictures vaguely show how I did it. They’re not very interesting, I know. I threw them up here as more of a central reference point for me down the road.
Complete '03 WRX bulkhead wiring harness
Everything through that grommet I need.
To transmission
Seperate SMJ from main loom
Seperated
Leave length
Complete front harness
SMJ was the only thing I needed off front harness
Complete bulkhead wiring harness/Other half of SMJ harness
Plastic shield removed (remember the 2 grounds)
Old 03-19-2013   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Project Slowbaru
I had NO idea you were on here. Lol. This is gonna be a fun car man!
1998 Spyder AWD
567hp
490tq
Old 03-19-2013   #3
LingLing
AznKraut
LingLing's Avatar
LMFAO! Never put 2 and 2 together?! That's funny shit right there.
I'm excited! I feel like things are coming together. Now that I'm waist deep, the wiring doesn't scare me anymore. I know I don't need to outsource the job.
Car will be very fun for a DD. Just need to get a better trans and rear diff.
I'll have some good stuff coming up later. Hopefully I can have the entire WRX harness done, and start tearing in to the Legacy harness tonight.
Freshly loomed wiring harness...Yummmm.
Old 03-19-2013   #4
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
BUMMER FOR YOU!!! i just sold my 6speed swap for hella cheap..
Originally Posted by 311evo
Old 03-19-2013   #5
LingLing
AznKraut
LingLing's Avatar
I've seen a few good 6-Speed swaps get sold recently. It's okay. A 6-speed swap isn't in the budget this year
Updated OP a bit. More pictures coming later tonight.
Old 03-19-2013   #6
LingLing
AznKraut
LingLing's Avatar
Just more notes. Sorry guys, I've been working all day on this and am going to grab the VF37 setup in about an hour. I'll create a true project thread tonight...If I don't get distracted by more wiring.
-FPC harness okay. Solder in length.
Signal 1 (A13) LgR Signal 2 (C15) VW [Take off main harness. + to length]
Grounds from FPC?? + to length, check schematic, reference pinout sheet.
-TPS Signal 1 (B7) Lg (Fully closed 0.2-1.0/Fully open 4.2-4.7) + to length
Old 03-19-2013   #7
That looks like a horrible time to me! Wiring ftl.
Need to post up more info y0!
Old 03-19-2013   #8
93gtpeater
Drives: cbr 1000rr repsol
What the hell are you building
Old 03-19-2013   #9
LingLing
AznKraut
LingLing's Avatar
Picked up the VF setup I'll be using. Can't say no to a setup with less than 30K.
This should be a fun street turbo. The VF37 is a twin scroll, so I'll get nice quick spool, and hopefully a nice wide powerband. From what I've deducted I'll have slightly quicker spool up than a 16g. I'm a little worried the power will drop off up top, but I've never ran a twin scroll turbo before so I can't compare the difference (if any) in top end power. However, what I want to use it for, lots of usable low/mid range is the ticket.
The downpipe that came with what I bought has a cat. Thought about gutting it....Oh wait, no I didn't. The downpipe currently on the car matches the rest of the exhaust, and will flow much better. Of course using the catless DP will help reduce spool up time too.
The single scroll downpipe flange I have is slightly different than the twin scroll. They use the same mounting points, but are internally cut out different. So, to save some money I'm going to take the grinder to the single scroll downpipe, and match it to the twin scroll gasket so exhaust flow isn't affected. There's barely any difference between the two. I found a picture showing how little you have to take off to make it match.
*The gasket is sitting on the flange. It look me a minute to realize what was going on*
Well, I have a few Monster's in the fridge, an Australian V8 Supercar race on the boob tube and a harness to make. Later!
Old 03-19-2013   #10
blageo23
AWD4G64
blageo23's Avatar
Don't forget ARP head studs and OEM head gaskets
1998 Spyder AWD
567hp
490tq
Old 03-19-2013   #11
LingLing
AznKraut
LingLing's Avatar
Oh yeah, I forgot about those! :P
Sad that the PO remembers more about a car I've had for almost a year. Lol!
Old 03-19-2013   #12
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
picture of the actual car and engine mayne? Load em up!
Old 03-19-2013   #13
^^What he said. Are you going to do an up-pipe as well? Now would be the time to do it, they are a whore to do with everything in the car.
Old 03-19-2013   #14
LingLing
AznKraut
LingLing's Avatar
Haha! I'm so focused on the wiring merge I forgot about the actual car. I'll get some up soon. No current engine shots. But I'll take some tomorrow when it's light out.
Definitely doing an catless up-pipe. I think I'm going to put a few resonators in to quiet it down. I don't want to get hassled by the man in blue about my exhaust.
Old 03-19-2013   #15
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
You are more of a Man that I am. When I swapped ecu's in my 98 Leggy I had Iwire do my harness. lol.
Cant wait to see more of this. I love the BD style cars. I really want another one.
Old 03-19-2013   #16
LingLing
AznKraut
LingLing's Avatar
There's something special about BD's. Even today, I don't think they look outdated. I really like the 2.5RS front end on the Legacy too. The swap really beefs the look of the front end up.
I can't puff my chest out too much. Originally I was going to ship them out to a guy CA. lol But I don't learn anything by outsourcing the work, and I could use $500 for other things.
Old 03-19-2013   #17
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
I got some pics of mine on Photobucket. It was pretty nice. JDM projector headlights and side markers. And my turbo setup was pretty much stock wrx. Even had a TMIC than cut a hole in the Leggy hood for a wrx scoop. Lol. Was a pain, but learned alot on that build.
Glad to see ya working on one. Can't wait to see how far you take it.
Old 03-19-2013   #18
LingLing
AznKraut
LingLing's Avatar
I love the JDM projectors. I have a set on the car now. But they're so grimy it's embarrassing. I have to bring them inside and clean them out.
What year of WRX did you get your TMIC off of? I got a good deal on one off an 06, but isn't very tall, and has this weird plastic shroud over the top. Even though I don't think it'll make a difference in my numbers, I've been debating on selling the one I have and getting a different one. I think I have to be mindful of size. It seems pretty cramped between the TB and firewall.
Old 03-19-2013   #19
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
If i Remember right the 06 is the one you want. I had the older one. The tall one. And I had to do some slight metal work to get it to fit. I had to dent the hood support in the back, and relocate the ignitor so ti would clear. Let me find a pic of how it was on the car.
Old 03-19-2013   #20
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
To get this one to fit I had to move some things underneath and than also trim the neck down on the Throttle body just so it would clear everything. It was not fun. But it was cheap, and at the time I couldn't get the newer style one.
But, I was working with a Ej22E intake manifold. It might be different for the EJ22T intake manifold.
