Old 07-01-2013   #1
import_boi
Drives: ae86,2ga,
6bolt 2ga issues "help Please"
Just changed the tps but the engine sputters when revving. I haven't had a chance to drive the car yet. Another issue I'm concerned about is after I shut the car off. It makes clicking noise??? I thought maybe a relay?? So I unplugged the battery and it still goes on. It sounds like its coming from the injector area but it got too dark to work on the car.
Mods: 6 bolt block, new machined head, s16g, Evo 8/9 injector, EPROM, 2g maf
I would really appreciate any advice
Thank you mits style
import_boi is offline   Reply With Quote
Old 07-01-2013   #2
import_boi
Drives: ae86,2ga,
Re: 6bolt 2ga issues "help Please"
Old 07-01-2013   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Clicking sound is normal. If its quick few seconds after shutdown.
You have to adjust your tps to I don't know how to do it without link though.
Sputter could also come from plugs and wires to.
Have you done a BLT?
Old 07-02-2013   #4
Are you using the 1g or 2g cam angle sensor? If using the 1g/6bolt style, did you invert the cam signal in the eprom or switch the injector wires?
Old 07-02-2013   #5
import_boi
Drives: ae86,2ga,
What's a BLt???
Spark plugs are black, wires are new
I'm runnIng 1g cas. Cas is wired to EPROM.
Old 07-02-2013   #6
Originally Posted by import_boi View Post
What's a BLt???
Bacon, lettuce, tomato. I prefer a little light mayo and a whole grain bread.
Old 07-02-2013   #7
Fran05
Drives: DSM
LOL
Old 07-02-2013   #8
dsmreck
dsmreck's Avatar
Drives: 98 gsx
did it start this after the injector swap? correct firing order? timing good? i'm tired
Old 07-02-2013   #9
import_boi
Drives: ae86,2ga,
Do u guys think it could be a power transistor? I'll try to upload a video when I get off work
Old 07-02-2013   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Blt=Boost leak test.
Old 07-02-2013   #11
dsmreck
dsmreck's Avatar
Drives: 98 gsx
f that sell the motor to me
Old 07-03-2013   #12
import_boi
Drives: ae86,2ga,
It starts n runs. The issue is rough idle n it is hard to rev
Old 07-05-2013   #13
import_boi
Drives: ae86,2ga,
Found out its a big exhaust leak. I'm just gonna buy a bep housing for my turbo n go from there
