Old 07-18-2013   #1
97gsexx
97gsexx's Avatar
Drives: 97 talon
Car dies when grounding timing through link
I have a question regarding ignition timing. I dialed in my 1650cc injectors and at idle everything looks good except my timing varies from 7*-17* at idle. Before dialing in my injectors I verified that my ignition base timing was at 5* using a timing light. Now, when I attempt to check timing and check the ground timing box in link, the car dies.
When I start the car with the timing grounded, the car dies as soon as the front o2 cycles. I have read that it is normal for timing to bounce around during idle but 17* seems a little high. I have also read that the car should run rough when grounding timing through link, but not die.
Has anyone experienced this issue? Thanks in advance.
Old 07-18-2013   #2
Re: Car dies when grounding timing through link
Where are you seeing it bounce around?
Are you talking physically or in link?
Old 07-18-2013   #3
97gsexx
97gsexx's Avatar
Drives: 97 talon
In link
Old 07-18-2013   #4
97gsexx
97gsexx's Avatar
Drives: 97 talon
I would assume my base timing is still at 5* since I haven't touched the cas since I checked it. I just want to verify that it's still at 5* since my timing reads high on link and did some idle tuning. The problem is I can't check it because my car dies as soon as I ground timing in link.
Here is a log of the car idling. I ended the log before I grounded timing so it doesn't show the car dying. The second log in the link is the most updated one.
http://www.dsmlink.com/forums/showthread.php?t=77228
Old 07-18-2013   #5
I'd turn my CAS one way so timing is way advanced then try grounding it.
I can't look since i'm at work right now. But depending if your idle is fluctuating timing would a little bit with it. Look at direct access and see what it looks like.
Old 07-18-2013   #6
Open up your BISS a lot more and set your idle target rpm higher. It is probably relying on ignition timing too much to idle the car instead of the IAC and BISS screw. Turning off closed loop fueling might help too.
Old 07-18-2013   #7
97gsexx
97gsexx's Avatar
Drives: 97 talon
Shane, are recommending doing this just so I will be able to ground my timing/check base timing? Or are you saying I should make these adjustments for good?
Thanks
Old 07-18-2013   #8
97gsexx
97gsexx's Avatar
Drives: 97 talon
Thanks for the help guys, I will give that a shot when I get home.
Old 07-18-2013   #9
So you can check base timing.
Old 07-23-2013   #10
97gsexx
97gsexx's Avatar
Drives: 97 talon
Hey guys, thanks again for your help. I raised my idle and messed around with deadtime and was able to ground timing without the car dying. Base timing was off and is now at 5*. I did some idle tuning and everything looks good for the most part. Only issue is that the rpms bounce from 950-1150 and sometimes the car almost dies. I tried adding more deadtime and lowering the mafcomp sliders and it helped a little bit but the rpms still bounce around. Deadtime is at 980 so I don't know if I should add anymore or not. Any suggestions?
I can't attach a log on here so here is a link where you can view it:
http://www.dsmlink.com/forums/showth...317#post623317
97 gsx (sold)
97 talon tsi awd 🐼
Old 07-23-2013   #11
97gsexx
97gsexx's Avatar
Drives: 97 talon
Isc settles at 30. Combfueltrims hovers around 0%. TPS is at .63. Running narrowband sim. Have the idle set to target 950 rpms. Br7es plugs gapped at .024 (on e85). As far as I know, I have everything set up correctly at idle so I am not sure why the idle bounces around. I am looking for a catch can with an fittings so I can connect the breather line from the vc to my fp intake which has a bung welded in for a -10 an fitting. I currently have the breather on the vc vented to atmosphere, could that be contributing the rpm trouble?
97 gsx (sold)
97 talon tsi awd 🐼
