Old 09-25-2014   #1
blesi660r
blesi660r's Avatar
What's the good word on tranny fluid?
Been a while since I've delta with tranny fluid for the dsm's, used to use synchro mesh etc, so my Q is what is everyone using now? What mix or what fluid, also what do you guys recommend for the tcase and rear end.
Just couldn't stay away.
Old 09-25-2014   #2
jeremy1375
jeremy1375's Avatar
Re: What's the good word on tranny fluid?
Mines been shifting well on Amsoil MTG. I picked it up at North Branch Synthetics for dealer price of $11.45/qt IIRC.
Old 09-26-2014   #3
MTG is a good fluid, but its a 90wt oil rather than 85wt which these trannies want.
Old 09-25-2014   #4
Most people use the Redline cocktail, 2qt of MT90 and 1qt of MTL mixed up and then put into tranny and rear diff.
Old 09-26-2014   #5
blesi660r
blesi660r's Avatar
I will check that out.
Old 09-26-2014   #6
blesi660r
blesi660r's Avatar
Stupid question - 1qt of MTL? Sorry guys it's been a while
Old 09-26-2014   #7
blesi660r
blesi660r's Avatar
Never mind my dumb self lol figured it out.
Old 09-26-2014   #8
Good ol red line mix or I'd use AMSoil.
Old 09-26-2014   #9
b00sted_spyder
I used redline in my eclipse, corolla, and mr2. Good stuff.
Old 09-26-2014   #10
Redline MT-85 has eliminated the need for the Redline cocktail. Redline is the only transmission fluid I use, and I'm about as anal as it gets when it comes to shifter feel.
Old 09-26-2014   #11
curt_gendron
curt_gendron's Avatar
Yeah, the new Redline MT-85 is the way to go. No mixing. Most of the old Mitsu trannies (3/S and DSM) are using this. I'm probably due on changing my three.
Minnesota 3/S
Old 09-26-2014   #12
Exactly what i was going to say, just get MT-85. I buy it off Amazon.
Old 09-26-2014   #13
The Evo 8/9 also use the MT-85, and the X can too in warmer climates.
Old 09-26-2014   #14
blesi660r
blesi660r's Avatar
That's really good to know a lot less hassle. You guys know of a place to get locally I did see orileys carrys it but haven't stopped in there to see if they have it on shelf. Might just order it when I order a new friction surface for my fidanza.
Old 09-26-2014   #15
MAP stocks it.
Old 09-26-2014   #16
jeremy1375
jeremy1375's Avatar
^ I read through the threads on tuners before I decided to try it. Couldn't find any first hand evidence of anyone running into problems with it.
Shifting felt less notchy to me with the amsoil compared to redline after installing new bronze synchro rings from Jack's in two different transmissions.
Has the amsoil caused any type of failure for anyone here?
Old 01-03-2015   #17
blesi660r
blesi660r's Avatar
So you fellas are using mt-85 in the trans and in the transfer case.
Old 01-05-2015   #18
Transmission only. The transfer case takes a GL-5 90W fluid, such as Mitsu's OEM Diaqueen 90W LSD. If you'd prefer aftermarket synthetic, you can use Mobil 1 75W-90, Redline 75W-90, etc.
*edit*
The above info is for Evos, I would think DSM's would be the same, but you'll need to verify that.
Old 01-05-2015   #19
blesi660r
blesi660r's Avatar
I've done some searching on tuners and it's kind of a mix of answers... drive train is finally going back in the talon this weekend so I'm going to have to figure it out soon, probably just a little more searching on tuners and I'll find then correct answers, but I did find a kit of redline that I think will work that comes with everything I'll need. So you are correct kracka.
http://www.maximalperformance.com/fl...line-fluid-kit
Old 01-06-2015   #20
Redline says to use the MT-85 in the transmission and transfer case.
http://www.redlineoil.com/application.aspx
