Old 10-05-2014   #1
Wanted, garage heat!
Looking to get some heat in my garage. Something like a 60k BTU NG forced air heater. Need a gas line ran, a heater, and installation. Anyone know someone that does this for a reasonable price, any referrals?
Old 10-05-2014   #2
Re: Wanted, garage heat!
I'll join this request.
But I have a heater to install already.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 10-05-2014   #3
I replied to some CL ad's, I'll let you know if I find any that are the right amount of sketchy.
Old 10-05-2014   #4
they are so easy to put in. I put one in the town house in maple grove and then when we moved I put it in the house in plymouth.
best place to find a good size one is on k-bid
Old 10-05-2014   #5
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I have a coworker that does HVAC on the side. He is licensed certified etc. I'll ask him tomarow if he wants somemore work.
11.35 @ 120mph
Old 10-06-2014   #6
Sweet, lemme know!
Old 10-06-2014   #7
carltalon
carltalon's Avatar
Sweet, lemme know!
He said that he could do it. He is out about 2 weeks right now and would want to look at the job before quoting a price. He can also get good prices on furnaces.
If anyone wants a quote PM me with your contact info and I'll get it to him.
11.35 @ 120mph
Old 10-06-2014   #8
Sent
GSX - 571whp/490wtq
Sienna
Old 10-06-2014   #9
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
i would be interested in this as well
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 10-06-2014   #10
I put mine in including the plumbing, it's no big deal. Mines a lot bigger 60k btu.
Old 11-25-2014   #11
Never heard from anyone, and I know bman hasn't either.
Anyone know anyone? It's cold out there!
GSX - 571whp/490wtq
Sienna
Old 11-25-2014   #12
carltalon
carltalon's Avatar
Sorry My guy from work has been super busy. And I totaly spaced on updating here.
11.35 @ 120mph
Old 11-25-2014   #13
Old 11-25-2014   #14
I've struck out with 2 CL guys that dont get back to me. It's already cold out, bummed I thought I'd have heat by now.
Old 11-26-2014   #15
Just put it in, it's about as tough as putting in a carburetor.
Old 11-26-2014   #16
There is a CL ad that looks promising, I'll forward it to you to see if it's someone you've already tried.
To get from my line/furnace area to my garage will take some work. Not something I want to tackle my first time.
GSX - 571whp/490wtq
Sienna
Old 11-26-2014   #17
Come check mine out some time, I just ran copper tubing from my basement to my garage. Just don't smoke.
Old 11-26-2014   #18
Gas line is super easy now, use the flexible stainless stuff. I just ran a line 55' and it took me an hour to do it. CSST is what they call it and Menards has the better stuff. Should only need a 1/2" line run to it. I scored a 30k BTU heater on CL for $35 to supplement the in floor heat. All hooked up and heating for $150 total.
Old 12-02-2014   #19
Hmm. I may investigate this option. I may just mount the heater, run this kind of line, and then see how I feel about the last connection to the houses gas line.
What's used to seal the connections? Would I be shutting down the entire houses gas supply to do this or just the section I'm working on?
GSX - 571whp/490wtq
Sienna
Old 12-11-2014   #20
jeremy1375
jeremy1375's Avatar
I installed a ventless heater a couple years ago. The supply coming into my house is 2 psi. The heater will list specifications for gas pressure. IIRC, the specs for input pressure on mine mine were 5-10.5" inches of water. I had to install a regulator and put together a diy manometer to set the pressure. The heater won't work right if the pressure is wrong.
