Old 07-11-2004   #1
ACRucrazy
Well, installed my Dynojet widband this weekend, Everything went great!
Have the gauge next to the stock boost gauge. The Commander is placed in the very bottom pocket of the dash.
Did a dozen or so pulls, 3rd and 4th gear, all with AFR between 11.5-11.9.
Wierd, didnt change anything on the car. FPR, injectors, all the same.
Have yet to install the map clamp.
The 02 is installed in the racepipe, between the upstream and downstream 02. I routed the wires through the shifter cable grommet, and have the loom under the heatshield and between the body of the car.
Heres some of the logs exported to a text file.
2nd-3rd gear pull
TimeSec TP% RPM AFR
243.381 007 2810 14.7
243.591 001 2787 14.6
243.801 001 2606 14.3
244.012 -01 2351 14.7
244.222 099 2484 14.7
244.432 101 4141 13.2
244.522 102 4088 12.2
244.723 101 4059 11.5
244.953 102 4240 11.4
245.163 102 4355 11.6
245.384 103 4456 11.4
245.594 103 4571 11.4
245.804 101 4593 11.4
245.834 104 4630 11.4
245.924 101 4760 11.4
246.125 101 4851 11.5
246.335 104 4958 11.6
246.545 102 5049 11.6
246.756 103 5154 11.7
246.966 103 5256 11.7
247.176 103 5383 11.7
247.386 103 5443 11.7
247.597 103 5547 11.7
247.807 103 5556 11.8
247.837 104 5629 11.7
248.037 006 5712 11.7
248.248 001 5438 11.0
248.328 103 4983 13.4
248.528 103 4107 11.0
248.748 103 4192 11.1
248.959 101 4246 11.5
249.169 102 4283 11.4
249.380 103 4350 11.2
249.590 103 4386 11.2
249.801 103 4400 11.2
249.831 102 4459 11.3
250.031 103 4503 11.3
250.242 102 4541 11.4
250.452 103 4587 11.4
250.662 103 4648 11.5
250.872 103 4689 11.5
251.083 103 4721 11.5
251.293 104 4737 11.6
251.333 103 4797 11.6
251.533 104 4830 11.6
251.764 060 4847 11.6
251.834 001 4417 14.2
252.034 001 4028 14.8
252.244 001 3775 13.7
252.455 001 3505 13.1
252.665 001 3242 13.8
252.875 001 2958 14.4
253.086 -01 2703 13.9
253.296 -01 2450 14.0
Slow stuff
Old 07-11-2004   #2
ACRucrazy
4th gear roll on.
TimeSec TP% RPM AFR
323.435 004 2248 14.8
323.645 004 2238 14.8
323.855 077 2237 14.2
324.066 103 2263 13.8
324.276 103 2290 12.9
324.486 101 2325 13.2
324.697 101 2360 13.0
324.907 100 2405 12.7
325.117 101 2455 12.6
325.327 103 2494 11.8
325.538 103 2551 11.5
325.748 102 2609 11.8
325.958 102 2665 12.2
326.169 101 2723 11.8
326.399 101 2776 11.8
326.609 103 2793 11.8
326.659 101 2826 11.8
326.760 102 2837 11.8
326.860 101 2864 11.8
326.960 101 2924 11.8
327.160 101 2974 11.7
327.370 102 3041 11.6
327.581 101 3086 11.5
327.791 101 3148 11.5
328.001 101 3185 11.4
328.212 101 3259 11.4
328.422 101 3262 11.4
328.462 102 3309 11.4
328.662 103 3344 11.4
328.873 103 3377 11.4
328.963 102 3408 11.4
329.063 102 3453 11.4
329.263 103 3505 11.4
329.483 103 3554 11.4
329.694 102 3593 11.4
329.904 101 3657 11.4
330.114 101 3659 11.4
330.164 101 3726 11.4
330.365 101 3728 11.4
330.465 103 3794 11.4
330.665 103 3831 11.4
330.875 101 3879 11.3
331.086 102 3954 11.3
331.296 102 3954 11.3
331.366 101 3977 11.3
331.466 103 4021 11.3
331.667 103 4037 11.3
331.767 102 4097 11.2
331.967 102 4119 11.2
332.177 102 4154 11.2
332.217 104 4184 11.3
332.418 102 4240 11.2
332.628 103 4291 11.3
332.838 001 4073 10.4
333.049 001 3700 14.3
333.259 001 3417 15.7
333.469 000 3209 12.3
333.679 003 2972 12.6
333.890 000 2726 12.6
334.100 000 2687 12.6
334.130 002 2471 13.6
334.330 000 2258 14.5
334.541 003 2081 14.2
334.751 001 1855 14.3
Slow stuff
Old 07-11-2004   #3
Enes
Enes's Avatar
that is pretty sweet, what is suggested for your engines for the afr .. i know some cars like it leaner than others..
-E
Old 07-12-2004   #4
ACRucrazy
From what I can gather 11.5 is what everyone shoots for. So im right on.
I wanted to do a 4th gear roll from real deep to see what it would read, and yup... it was a bit lean for a second, not like im gonna be racin from 2200 in 4th gear though! LOL.
Slow stuff
Old 07-12-2004   #5
Sweet, they make a golf-cart model:
http://www.dynolab.net/html/cart.htm
Seriously, though, how does this compare to an AEM UEGO setup? Better? Worse?
-scheides
Old 07-12-2004   #6
ACRucrazy
I wouldnt even put this in the same catagory as AEM.
AEM doesnt datalog, its just a gauge.
Dynojet gauge (made BY autometer) goes from 10.0:1-18.0:1.. aem goes from 11-17?
This can be had CHEAPER then the AEM...
Im diggin it, already talkin with dynojet, they are upgrading the software so you can fwd, rwd, and edit the playback for the next upgrade.
The gauge has a programable warning light, or you can add another LED light and program the warning, also can hook up an controllable out put... say if AFR is below 12.0 and RPM is above 3000 and TPS is above 80% activate this output,,, IE Nitrous, hi boost, whatever...
Datalogs not only AFR, but RPM and TP, Aem doesnt tell you RPM or TP.
Slow stuff
