07-22-2004
Business as usual
I had my head in for some porting and the shop reomved the CAS and I recieved it in the box. When installing it, is it possible to get it 180* off or does reseting the battery erase the memory? I looked at the shaft and couldn't see a difference as to which way it is supposed to be put on. What could go wrong if it is installed wrong?
97 Viper GTS
07-23-2004
Drives: 2012 Audi S4
In my Laser, it was discovered that the CAS was 180* off. However, it started up fine and didn't seem to have any issues... that is until it spun a bearing.
07-23-2004
Business as usual
Thanks, I plan on starting the car tomorrow if all goes well. Just hoping I connected everything up...
97 Viper GTS
07-23-2004
Hellbound
I think the signal will be the same even if its 180 off.
-Nulli Secundus-
07-24-2004
Business as usual
Thanks alot. The car started tonight but has issues. I will check that tomorrow. The car idles at ~3000 rpm. I assume I just need to adjust the throttle cable.
97 Viper GTS
07-25-2004
yup, throttle cable prolly too tight. I have to have a tiny tiny bit of slack in mine. If's its tight at all, the thing will rev way up at idle. What other issues you having?
07-25-2004
Business as usual
That is all that I have not fixed yet (hopefully). I'll find out for sure tomorrow night when I can dig into it again.
97 Viper GTS
07-25-2004
throttle cable adjustment should take like 1 minute max. Anywho, good luck man
