Old 08-29-2004   #1
Enes
Enes's Avatar
2g fwd flywheel, i am going to get it resurfaced before i put the trany back in, becuase i noticed when the car in neutral the tires still move a little bit while the car is in the air ..
so what should i have the flywheel steped to? when i took it to red rooster they didn' even ask me what car its for... so how will they know what to step it to?
i checked with a caliper not the greatest measuring tool but it works..
and it measured anywhere from .559 to .620 on the four oposite sides..
preasure plate act2600
and standard street disk
now i know i know great precision tool it is not..
whats the standard?
-E
Old 08-29-2004   #2
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
Doesnt it depend onwhat clutch you are using? I know you are supposed to have it machine to soemthing different than stock spec if you are using ACT...
Khadgar is offline   Reply With Quote
Old 08-29-2004   #3
Enes
Enes's Avatar
http://www.roadraceengineering.com/clutcha...lywheeltech.htm
great tutorial.. i should of known..
Old 08-29-2004   #4
Enes
Enes's Avatar
i will take it in and have them do it for .610 steped ..
-E
Old 08-29-2004   #5
That's correct sir.
Old 08-29-2004   #6
I talked with a napa machineshop guy and he said they just take off the same from the clutch mounting pads and the friction surface. But a .610 step will provide a little more clamping force then the stock step.
Old 08-29-2004   #7
LightningGSX
Hellbound
Make sure you verify the step height before you install it.Also, NAPA is the wrong place to get information.
-Nulli Secundus-
Old 08-29-2004   #8
joem
Drives: 1991 Talon awd auto
Thats what Ive heard.
joe
Old 08-29-2004   #9
Enes
Enes's Avatar
factory is .612 i might just go with that
-E
