Old 12-03-2004   #1
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
Please help! RPM won't go over 2200.
Hey guys and gals. i just finished rebuilding the bottom end of my motor and removing the balancer shafts. when i put the motor back in the car it wont run over 2200 rpms and it runs really rough at idle. i have tried almost everything i can think of. i ran mmcd and it said i had a bad mas so i replaced it. Nothing changed! If you guys know of anything that would cause this please help!
This is what i have into my car.
TMO EPROM ECU
FMIC
Apexi SAFC
2g MAS
balancer shaft block off kit
RC 550 injectors
walbro fuel pump
boost controller
AEM true time cam gears
Je pistons and rings and bearings
egr block out plate
ACT clutch
WEB cams street grind
head is ported polished 5 angle grind decked and dipped
and lots of other stuff i cant think of right now
PLEASE HELP IM STUMPED!!!!!!!!!
Thanks
MATT
Old 12-03-2004   #2
Plug wires on right? Timing belt on right? Cams will make it idle rough, but it should rev.
Old 12-03-2004   #3
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Sounds like your timing belt is off a little.
What do you mean it wont run above 2200? Does it die or just miss/buck like hell?
Old 12-03-2004   #4
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
no its almost like hitting a rev limiter and it barely idles
Old 12-03-2004   #5
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
i doubble and triple checked all the timing and connections also
Old 12-03-2004   #6
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Maybe there is a malfuntion with the TMO ECU's Stuttrbox/rev limiter?
Did you run the modded ECU before you built this motor or is it new aswell?
Old 12-03-2004   #7
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
i ran the tmo ecu before the rebuild . i will check the afc numbers
Old 12-03-2004   #8
What does the hz say on the datalogger and afc when it is idling?
Old 12-04-2004   #9
LightningGSX
Hellbound
This doesn't happen very often, but it sounds like it may be the analog ground inside the ECU.Unplug the ECU, take a multimeter and test for continuity between pins 24 and 106, then check between pins 17 and 106.Lie I said, this is a long shot, but this is pretty much exactly what happens when the analog ground fries in the ECU.Other than that, it could be the old DSM capacitor problem, bad caps will have a different effects/symptoms on nearly every ECU.
-Nulli Secundus-
Old 12-04-2004   #10
I'm thinking ECU as well. Try unplugging your stutterbox clutch wire if you have it hooked up.
Old 12-04-2004   #11
** changed the title to be more fitting, as it should have just been deleted. Read the rules people! **
Old 12-05-2004   #12
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
hey thanks guys ill try that and see what happens.
i appreciate all the help.
matt
Old 12-05-2004   #13
john
Business as usual
john's Avatar
1g or 2g? If it is a 2g, check to make sure the MAS plug is connected all the way. We had the same symptoms on James' 2g.
EDIT: looking at your mods again, I am guessing it is a 1g. Check the plug anyhow.
97 Viper GTS
