Old 12-06-2004   #1
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
When does the 1G BOV start to leak?
I tired to search, and all I got was:
Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : 1G, BOV
So how much boost can the stock unmodified 1G BOV hold untill it becomes leaky?
Old 12-06-2004   #2
carltalon
carltalon's Avatar
damn you jeff cant you sighn me out yet just put my other one back on and you'll be fine til like 30 psi
Old 12-06-2004   #3
carltalon
carltalon's Avatar
It wont let me log you out. I'm brining your cruched and modifed with, so If I cant hold over 20psi I'm switchen to it.
Old 12-06-2004   #4
I have heard crushed that they can hold up to 21 psi.
CRAIG
Old 12-06-2004   #5
About 20psi would be fine.
Old 12-06-2004   #6
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
about 18-19 unmolested. Up to 25psi when crushed properly.
Old 12-06-2004   #7
PSI2HI
Buy a good one and not worry about it. IMO the only thing a DSM BOV is good for is a homemade/junkyard turbo kit.
PSI2HI is offline   Reply With Quote
Old 12-07-2004   #8
carltalon
carltalon's Avatar
Jeff he must have seen your car before
Old 12-08-2004   #9
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I dont think i followed wut kept occuring on the same login name lol. As i was told, up to 20 MAX uncrushed and maybe 25ish crushed. You can pick up a nice BOV for 200 or less easily. If you can come up with that money, id advise that route.. prettier tooooo!
- Josh L.P.
Old 12-07-2004   #10
jeffescortlx
I forgot to mention it's for my home made junk yard turbo car.
jeffescortlx is offline   Reply With Quote
Old 12-20-2004   #11
LightningGSX
Hellbound
Re: When does the 1G BOV start to leak?
Why don't you just do a test and see? Rig up one of them boost leak testers, but put a vacuum nipple on it too, plug the BOV vacuum line into that nipple(which will simulate normal boost operation).Slowly pressurise it, watch the boost gauge, and see when it cracks open(probably by a noticable drop it PSI)
-Nulli Secundus-
Old 12-20-2004   #12
carltalon
carltalon's Avatar
We found the limits of the stock BOV while on the dyno. The stock uncrushed would leak around 17 psi. The crushed was good for over 22 psi.
Old 12-22-2004   #13
jeffescortlx
yep, gained 12whp just by swapping to a crushed BOV.
But the crushed one would'nt open fast enough compared to the uncrushed, so the pipes would blow off when I let off the gas.
Ford Escort 1.9 SOHC 2150lbs
212.2whp 262.6tq
Old 12-29-2004   #14
get a 2g one, i hear that one holds like 30psi, didnt you know that plastic is better then metal. LOL
Old 12-29-2004   #15
Next post in a tech area like this and I will ban you Tom. Just think about shit before you post for once.
Old 01-05-2005   #16
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
My 1g bov leaked at idle. After I setup my GM MAF and MAFT in blow-through configuration, I vented the 1g blow off valve. It would suck air in at idle sometimes and it got really annoying. I bought it from a friend who purchased it brand new so it wasn't worn out, just doesn't like to be vented.
Jim
Old 01-29-2005   #17
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
mine holds until 17psi then it leaks
Old 02-02-2005   #18
santa
Boost Spike
santa's Avatar
Mine holds fine past 21psi... Its crushed and a 1G junkyarder...lol
