Old 06-18-2005   #1
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Question Bastard 20G?
98 Tsi, AWD, Auto, 650 Injectors, 255 FP, dsmlink, Apexi N1 Exhaust, Injen Intake, EI FMIC.
What do you all think of this interesting hybrid turbo on the above car <my present system?>
http://www.slowboyracing.com/more.php?id=1977&
Looks like it could be a nice and easy to install power upgrade with that 20G comp wheel and TDO6H Exhaust side?
This would be a much simpler direct swap with my present bad Big 16 with all the oil, water, return and outlet fittings being exactly the same?
What's your 2 cents?
TIA......
Let the madness begin...
Old 06-18-2005   #2
john
Business as usual
john's Avatar
Re: Bastard 20G?
That is a pretty small 20g... It is like the one Jim (talon Fiero) had. I would definitly upgrade to the tdo6 exhaust housing if you decided on getting it. That would bring the price to $1000 where IMO you would be better off getting a buschur 20g. Being an auto, you may want to opt for the port job to help increase spool and as you are going to be running an external wastegate, you may want to research the turbo more and see if you should get it clipped to help prevent boost creep.
I believe there is a company who will upgrade your turbo to the same setup which would probly be cheaper. I would check with FP or extreme.
97 Viper GTS
Old 06-18-2005   #3
white 2g awd
Send a message via AIM to white 2g awd
Re: Bastard 20G?
it is fp, forcedperformance.com, its only like 375 i think, it sounds like a hell of a deal to me, and forced performance has some awesome turbos, so they have to know what they are doing.
ps ok, wait, they upgrade to the 18g.....here is the webpage, but i would still definatley think about it http://linux.forcedperformance.net/m...egory_Code=DSM
white 2g awd is offline   Reply With Quote
Old 06-19-2005   #4
Re: Bastard 20G?
Well if I'm remembering the specs on the FP Sleeper 16G correctly, we can compliment Slowboy on copying the FP Sleeper 16G: http://linux.forcedperformance.net/m...Code=DSM-Turbo
Old 06-19-2005   #5
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
I'm now also looking at this PTE Turbo as well:
http://www.slowboyracing.com/more.php?id=2190&
I know I'd need a new 3" intake, and Extreme Intercoolers will let me swap the outlet LICP pipe to fit a this turbo as well.
My question is what kind of changes would I need to make for the water and oil lines from my big 16 to install this new PTE SCM-5031E model?
Or is this SCM-5031E going to just be way to laggy on my Auto?
Should I stick to the smaller Bastard 20G for faster spool up, but less power?
Just looking for the right fit for my setup?
TIA.....
Old 06-19-2005   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Bastard 20G?
That is such a waste of money for "around 400whp". The Evo III 16g at half the price is good for almost that and has done 400whp in one car. If your going to spend that much why not get a AGP RS49T or a RS60T. Then when you do your tranny work and possibly get nitrous and you will be set. A 20g would probably be your best bet but if you want a new turbo, its going to be easier and cheaper to find a 50 trim. Just my $.02 on this topic.
Originally Posted by shoutbox
Old 06-19-2005   #7
Re: Bastard 20G?
Get a higher stall and lag won't be a problem, at least from a roll. Maybe some nitrous if lag is a problem from a stop.
Old 06-19-2005   #8
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
So Shane, you'd then go with this SCM-5031E, vs. a mitsu 20G, or this SBR bastard 20G overall?
Tranny, NO2 are going to have to happen next year, IF I want to continue to stay married!
For now just need the right size snail?
Many Thanks.....
Old 06-19-2005   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Bastard 20G?
If you go with the PTE 50 trim, you will need to block off the coolant lines as they do not take coolant lines. You will also need an oil line kit and possibly have to order a cast elbow to be welded on hte outlet pipe.
This is Carlos posting under James' name...
7/25/09
Old 06-19-2005   #10
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
Thanks much for all the great input gents.
I agree that the SBR Bastard 20G looks to be overpriced vs the EVO3.
I like the ease of install for the EVO3, but really would like a bit more power?
Also still kind of spooks me not have any water cooling, as I would like to keep this turbo going for a while?
A standard 20G uses water cooling, and should be good for about ~450 HP right or?
What are the details to swap in a 20G as far as the lines, and elbows?
TIA.......
Old 06-20-2005   #11
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
Did some more digging, and finally decided on this one, in prep for next year.
<Jet, you know atleast I didn't go with the V Trim..........:->
http://www.slowboyracing.com/more.php?id=2198&
Damm the the Torpeados.....
Old 06-20-2005   #12
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Re: Bastard 20G?
The 20g and 50 trim weren't big enough huh? You will need a bigger intake and probably some braided turbo lines now.
7/25/09
Old 06-20-2005   #13
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
The braided lines and 3" intake are on the way!
Just gotta figure out how to properly block off those water lines now?
Thanks for your help!
Old 06-20-2005   #14
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Post Re: Bastard 20G?
I'm pretty sure Shane was referring to upgrading your Torque Converter in your automatic. What modifications have you done to your auto?? If I remember correctly from your For Sale Ad, you hadn't listed anything for the tranny. The automatic is a pig that needs 3 things (IMO) for it to get results.
- Higher Stall Torque converter from IPT (Since it appears you have money to blow I'd say get the 9 1/2 inch Billet Converter)
- End clutch kit
- Shift kit
Old 06-20-2005   #15
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Bastard 20G?
30-31" FMIC will fit fine on a 2g. You probably wont need to take out the bumper beam across the front seeing its only 7" high. You will need to shave quite a bit off the back of the bumper cover to get it to go back on right but nothing major. My FMIC is 30.5x12x3.5 and all I had to do is remove the bumper beam and cut the bumper cover a little. Really wasnt all that big of a deal. Short route piping was easy to fab up and everything went together good. Shouldnt be too difficult for you. Good luck with it.
Whenever Mike gets out of the hospital you might want to talk to him about welding them shut for ya. If your a good welder or know someone that is then that would work too.
Old 06-20-2005   #16
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
Thanks much for the great tips man, as still just a n00b, I need all the help I can get to try to make this happen!
Old 06-20-2005   #17
john
Business as usual
john's Avatar
Re: Bastard 20G?
I hope you ordered a a big FMIC kit. You were worried about lag and you chose this turbo????? Nitrous would be a great choice now, increase spool and help you get out of the hole quicker.
97 Viper GTS
Old 06-20-2005   #18
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
The FMIC is a bar and plate 31 X 7 X 3.5 with 2.5" hard short route piping from the outlet all the way to the TB. Suppose to flow 800 CFM?
I agree I need both all the Tranny upgrades and the NO2, but that's just not going to happen this year cash wise. I'll just have to live with a laggy pig this summer and next spring upgrade again when I can afford to do so.
In the long run I think it's a solid plan, vs just dump it and take abiut a $10K bath.
Old 06-20-2005   #19
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Re: Bastard 20G?
Good luck getting the 31" i/c in front of your car. You will have to cut the crap out of the front frame rail, remove it or have longer route pipiing for it to work. You will probably need to remove the bumper support because it would be a bitch to cut. Are you planning on installing this stuff yourself? I know autos have a small chance of walking, but do you know if your car is crankwalking or already walked? You will want ARPs and a new HG for that turbo also.
I blew past my new copper sprayed HG 2 weeks ago with my 60 trim and that was on a run with 1.83 counts of knock. That gasket lasted 2 pulls so I don't think your stocker with stock head bolts could stand a chance.
7/25/09
Old 06-20-2005   #20
howslowcanyougo
Older than Dirt...
Re: Bastard 20G?
Supposely this FMIC will fit into a 2G, just measured it and guess it's only 30" including the end tanks. One way or the other were gonna have to just make it fit. Both my son, godson and myself are going to try to do as much work as we can do without stretching our skills too much to wreck stuff. Good point on the ARP's and the HG, will just have to turn the boost way down till I can get qpr or some good wrench to install them, as I never even seen them get installed, and don't want to wreck my junk ass 7 bolt, just yet.......:->
