Old 06-28-2005   #1
Enes
Enes's Avatar
MCCC stuff? suggest it?
http://vfaq.com/mods/MCCC.html
would you gearheads suggest doing the mccc stuff before i swap the cams in?
to clean up the head and crap as best as possible without taking it all apart..
-e
Old 06-28-2005   #2
Onefast99gsx
Re: MCCC stuff? suggest it?
I've used it and it works great. If you can't find it(in which you should be able to), you can use Seafoam. I'm not sure which which is stronger of the two as i've only used MCCC. Car smokes like a MOFO and you'll have to play with the throttle to keep it running.
Suggestion: Use a shit set of plugs if you have good ones in it.
Old 06-28-2005   #3
Enes
Enes's Avatar
where did you squirt it throu?
it would seam best throu one of the ports on the throttle body...
Old 06-28-2005   #4
Onefast99gsx
Yep, that's exactly where i did it from. Just pulled one of the hoses off that goes to the throttle body. I can't remember which hose but any one that sucks air in, which i believe they all do.
Old 06-29-2005   #5
I believe this is the stuff Barton used when he had his continual knock problems.
http://www.dsmstyle.com/forums/showt...highlight=MCCC
Old 07-01-2005   #6
john
Business as usual
john's Avatar
Read my post on here. It is more educational.
97 Viper GTS
Old 06-29-2005   #7
Enes
Enes's Avatar
cool sounds like a magical stuff ;p
Old 06-29-2005   #8
john
Business as usual
john's Avatar
I used it on my car to clean carbon off the piston tops. I just poured it into the spark plug holes, let it sit overnight, modified a shop vac hose to go in the holes and suck as much as I could out, used engine flush and did an oil change afterwards. It did run like crap until it was all burned out but it helped.
97 Viper GTS
Old 06-30-2005   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I thought it said right on the bottle for most Engine Flush like products not to use them on turbocharged engines?
And isn't MCCC supposed to be used on an engine that is running?
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 07-01-2005   #10
john
Business as usual
john's Avatar
Didn't read the instructions off the bottle, just off the internet.
Yes and no. Cleaned out some with the engine running through the pcv hose. Cleaned out most with the engine off spraying straight into the cylinders.
97 Viper GTS
