Old 08-02-2005   #1
Nash
Nash's Avatar
Oil Leak
I'm leaking oil from the bottom tensioner bolt hole. I replaced the front case with a new and put a new gasket on, it still leaked. I just pulled the case off and put a new gasket on it again and it's still leaking. Anyone have any idea why it's leaking from there? It's a 6 bolt 2.4l.
Old 08-02-2005   #2
Re: Oil Leak
I was thinking cracked case since there's an oil passage right next to that bolt, but if you changed it, I can only think that there's somthing wrong with the block. It's not the right way to do it, but have you tried smearing some RTV around the bolt just before you put it in?
Old 08-02-2005   #3
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Oil Leak
Yep, did that 3 times. It doesn't make any damn sense! What would cause the block to crack there? It would have to just be a weak spot in the block because there isn't any pressure on it there, and Mitsu isn't known for poor castings. He even tried some teflon tape on the threads with the RTV and it didn't do it. It absolutely poors out of there too, not just a drip, but a solid stream.
It leaks a steady stream from behind the bolt head?
Jim
Old 08-02-2005   #4
Nash
Nash's Avatar
Re: Oil Leak
Jim
It's from between the tensioner and the case is where it leaks from.
Old 08-02-2005   #5
Re: Oil Leak
Old 08-02-2005   #6
Re: Oil Leak
Yeah, he warmed it up to get it to leak, then tore it apart and turned the oil pump with a drill. It would just pour from the lower tensioner bolt hole.
Old 08-02-2005   #7
Nash
Nash's Avatar
Re: Oil Leak
It only seems to do it when the car is warm.
Old 08-02-2005   #8
Re: Oil Leak
It sounds like an issue with the block .
