Old 08-31-2005   #1
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Rebuild time!
Hey guys, it's about time for my rebuild, here's a list of what I've ordered.. Just wondering if I left anything out. Also, if you happen to read this Mike, please PM me a quote for this rebuild.
Eagle Connecting Rods $360
Wiseco Pistons $445
Topline Lower Gasket Kit $99 (I have an HKS metal HG that I will be using)
Water Pump $60
Clevite Rod Bearings $41
Clevite Main Bearings $60
Balance Shaft Eliminator $42
ARP HeadStuds $90
Turbo Gasket Kit $60
dsm10sec is offline   Reply With Quote
Old 08-31-2005   #2
Re: Rebuild time!
I would change a few things. Get your gaskets from Mitsu, don't use Clevites (get ACL's or King's from QPR), also get a turned down balance shaft from me or QPR.
Old 08-31-2005   #3
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: Rebuild time!
Mike is going to say " King bearings and mitsubishi gaskets".
Why do you think you need a metal HG by the way?
- Josh L.P.
Old 08-31-2005   #4
dsm10sec
dsm10sec's Avatar
Re: Rebuild time!
I probably don't, but I got it as a Christmas present last year and haven't had a chance to put it on.
Old 08-31-2005   #5
Outlaw1
Resident Redneck
Outlaw1's Avatar
Re: Rebuild time!
What's wrong with Clevite bearings?
Old 08-31-2005   #6
Re: Rebuild time!
Metal gasket, sell it.
Clevite bearings, no. Kings are a better bearing, so are acl's, the clevites were junk last year, and because of that, I won't even touch one.
Oh, and buy some damm mitsu gaskets .
Old 08-31-2005   #7
Re: Rebuild time!
The Clevite bearings are much poorer quality than the ACL or King's. Plan on deburring all of the bearings if you use Clevites. The holes and edges have burrs on them. I put ACL's in this time and they looked really nice. They are all very close to the same price too.
Old 08-31-2005   #8
Re: Rebuild time!
You forgot a front cover including new oil pump gears and a timing belt kit with new tensioner. The whole gasket set from Mitsu is $190 and includes turbo gaskets and even the nice 7cm one. And if you've already got the Clevites, they're fine if you debur them, otherwise get the ones others have suggested. The metal hg is nice, but if you're only running 25psi or less, the stock Mitsu that comes in the kit is more than adequate. Everything else looks good.
Old 08-31-2005   #9
Pimpin Dsmstyle
Br0k3N
Re: Rebuild time!
If you use a metal head gasket, you no longer have a fuse for the engine. Usually, if soemthing goes wrong, or it gets too hot, the gasket will go. I got news for ya, the metal one isnt going anywhere
- Josh L.P.
Old 08-31-2005   #10
dsm10sec
dsm10sec's Avatar
Re: Rebuild time!
No news, I've heard this discussed 10 times already on this forum.
Old 08-31-2005   #11
Re: Rebuild time!
I blew my metal hg out pretty quickly with a 20g and on pump gas.
Old 08-31-2005   #12
Pimpin Dsmstyle
Br0k3N
Re: Rebuild time!
Sorry guys. I was over exaggerating. I just know what I was told. Apparently I was not aware that you can keep the torque down and they will operate like a regular HG?
- Josh L.P.
Old 09-01-2005   #13
Re: Rebuild time!
This conversation is probably best left to those with first-hand experience.
Old 08-31-2005   #14
Pimpin Dsmstyle
Br0k3N
Re: Rebuild time!
If you've read the topic that many times, then why are you bothering with it? I'm not telling you what to do, I'm simply informing you that it could be a bad decision.
- Josh L.P.
Old 08-31-2005   #15
Re: Rebuild time!
It's not a bad decision, metal headgaskets are not bad. They can blow just like a normal gasket, just not quite as easily.
Old 08-31-2005   #16
Re: Rebuild time!
Don't torque your ARP headstuds to 110 ft-lbs and the metal headgasket might actually blow before a rod goes through the block. I have seen plenty of blown metal headgaskets. A lot of Hondas run stock metal headgaskets and they have no problem blowing them with some boost. The best way to go is to try not to blow them in the first place. It can be hard to keep a headgasket from leaking when you run high boost and nitrous together though. Even if you aren't knocking, the cylinder pressures can get very high with that combo and cause headgaskets to push coolant.
Old 08-31-2005   #17
santa
Boost Spike
santa's Avatar
Re: Rebuild time!
Well, if it was me I'd say use king bearings(trusted by top fuel dragstersm and formula one), have the block bored, honed with a tq. plate.(100ft. lbs), and also Decked along with the head because you need to have them both done to run the metal headgasket. New main bolts( there tq. to yeild bolts factory so I'd replace them), Qpr's BS elim, Valve job along with new guides.TT springs and retainers, Cam's bigger than stock(hks 272's?) Mitsu gaskets with copper spray, and also Mitsu timing components. Welded NEW front cover. Also use a quality Tq. wrench when assembling. Theres a lot more but thats just some basic's
Old 09-01-2005   #18
dsm10sec
dsm10sec's Avatar
Re: Rebuild time!
Actually, my head was rebuilt 1k miles ago, so I think I'll leave it alone. The next things on my list were valvetrain components but funds won't permit at the moment.
Old 09-01-2005   #19
CDeutsch
CDeutsch's Avatar
Re: Rebuild time!
New main bolts like Santa said. Use mitsu bolts unless you're going to line bore it.
06 Evo IX RS
99 Miata
