Old 10-02-2005   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Priming the oil pump and break in ?'s
I already have the head bolted to the new block and torqued down. The turbo, exh mani, intake mani, and such were all attached so that is taken care of. My main question is that I was told to prime the oil pump prior to starting the motor. I managed to forget exactly what I was supposed to do inorder to get that done. Do I just spin the oil pump gear with everything hooked up and wait until I see oil come out of the head, or do I do the timing belt and then spin the crankshaft?
Also I have heard a few suggestions on break in procedure on a new motor, and would like to get a few more. The one I have thought would work the best for me is vac pulls for the first 50-100 miles with straight 30w oil for the first 500 with changes at 50, 100, and 500. Low boost, not too much fuel and then after 500 miles start the fun. Any other personal methods out there? I just want to make sure this motor is taken care of as I am not rich enough to buy another built motor if something goes wrong.
In case it matters:
6 Bolt Block
9.5:1 JE's 20 over (used, supposedly once were Jet's)
New Eagle H-Beams
Kings bearings
Machined at Wags (QPR treatment except not torque plated)
QPR style b-shaft removal
New front case, oil pump, water pump, etc.
New Timing belt and components.
Thanks in advance!
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 10-02-2005   #2
Wizard50369
Send a message via AIM to Wizard50369 Send a message via MSN to Wizard50369 Send a message via Yahoo to Wizard50369
Re: Priming the oil pump and break in ?'s
I think i read somewhere to prime the engine, you take the Fuel Injector relay and crank the engine over for a little bit. I still need to research this a little more too cause I'm about to break in my new engine yay, 2 more DSMs back on the road.
Ignorance Is Not A Virtue
Wizard50369 is offline   Reply With Quote
Old 10-02-2005   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
This motor is on a stand, not in the car. I am hoping to have the complete longblock done and ready to startup before it even gets in the car.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-02-2005   #4
I believe you said the timing belt was off... If so spin the pump (Gear next to the crank) with a drill or a impact wrench on its highest setting. Thats really the only way to get the oil all around the motor. The other option is while its in the car, take the injector clips off the injectors and crank the car of a decent amount of time.
As far as break in processes. Everyone has their own opinion. There was a thread on this awhile back and a bunch of people chimed in their opinions. Might wanna look that up.
Old 10-02-2005   #5
CDeutsch
CDeutsch's Avatar
Make sure you disconnect the clutch switch so you can crank it without pushing in the clutch (in neutral obviously). You don't need to risk any wear on the thrust bearing before it has adequate oil.
Otherwise use a drill or air ratchet to spin the oil pump (with the timing belt off) like EclipseGST said.
06 Evo IX RS
99 Miata
Old 10-02-2005   #6
yeah, spin the pump while it is out of the car, then do it again when it is in the car and you are ready to fire it up. Break-in is way overratted. Most of it happens in the first 20 miles if you had a good plateau bore hone done. Mine went on the dyno with 23 miles on it
I would recommend 200 miles though. http://www.mototuneusa.com/break_in_secrets.htm
Old 10-02-2005   #7
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Cool thanks for all the info guys! As for the clutch switch, well since it was an auto before, none of that is there. So that won't be a concern.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-02-2005   #8
9.5:1 compression? I thought you were building a pump gas car.
Old 10-02-2005   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Well the pistons I bought from you I had to sell because I lost my job right after that. Then months later when I got a big severance check I found a motor ready to be built(machined, rods, pistons, assembly hardware, etc) that I got for a good price and that had the JE's as part of it. They wouldn't have been my first choice, but they'll work. My plans have also changed a bit since then so I will still be fine with these pistons.
And this is for my Talon, but if I end up building a motor for the Galant ever, it will be pump gas only.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-02-2005   #10
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
This is for the Galant right? It's a racecar. J/K
And just cause no one has said it, the oil pump needs to be spun clockwise.
Old 10-02-2005   #11
If you are going to run the factory ECU, get the timing maps in the ECU changed. The stock 1G maps are meant for a 7.8:1 compression motor, going to 8.5:1 can be hard enough with the kind of timing the 1G ECU wants to run.
Old 10-03-2005   #12
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Well, when it gets all done and broken in, it will be paying a visit to you so you can take care of that. Hopefully to make it easier I have DSMLink, with a wideband and GM MAP hooked in.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
