Old 11-16-2005   #1
mitfastgsx05
Curb Check
My friend hit a curb tonight on the ice and had the wheel turned so the wheel in push in,back and is bent a little bit. What part/s are broke and need to fix this?
help ASAP thanks
mitfastgsx05 is offline   Reply With Quote
Old 11-16-2005   #2
Re: Curb Check
Yeah, because we can tell that by you typing 2 sentences on the internet. The wheel and A-arm are probably bent, there could be a lot of other things too.
Old 11-16-2005   #3
dumb_ricer
Hates Everything
Drives: Neon
Re: Curb Check
He WILL need:
1. New Rim
2. Upper control arm
3. Lower control arm
4. Strut and Spring
5. Rack and Pinion
6. Tie rod ends
7. Bushings
8. CV joint
9. New tire
10. New rotors
11. New calipers
12. New brake pads
13. Wheel bearing
14. New wheel studs
15. New transmission axle seals
16. New transmission fluid
17. New Differential
18. New fender
19. New front bumper
20. New front end of the car
21. New bolts of all sorts
22. New cotter pins
23. Flamidation Valve
24. A-Arm
25. B-Arm
26. C-Arm
27. M-Arm
28. S-Arm
29. V-Arm
30. Z-Arm
There could also be other things that need to be replaced. Maybe you could even substitute the driver with someone that wont hit shit.
420A > LS1 > All Else
I > All else
Old 11-16-2005   #4
Re: Curb Check
Bingo.
Old 11-16-2005   #5
4Las90
4Las90's Avatar
Drives: Evo 8 RS
Send a message via AIM to 4Las90 Send a message via MSN to 4Las90
Re: Curb Check
he said bent a little guys come on. Some guy askin for help and you guys just go on bein dumb. At least you could ask him some questions that would help.
4Las90 is offline   Reply With Quote
Old 11-16-2005   #6
Re: Curb Check
Shut up, have a nice 7 day vacation. I am an even bigger asshole when I am sick than normal!!
Old 11-16-2005   #7
Re: Curb Check
BAM! That was awsome.
Old 11-16-2005   #8
Re: Curb Check
If he would have read the fucking rules there wouldn't be an issue here. With a vague post like the first one he is lucky I just didn't delete this all together. If it take 10 posts just to find out exactly what happened it gets pretty annoying.
And as for you, you should be calling anyone else dumb. But thanks for your contribution to the ban a member fund. Its people like you that are going to get us our new server.
Old 11-16-2005   #9
blageo23
AWD4G64
blageo23's Avatar
Re: Curb Check
Yah give more info and maybe like a pic or something. Or better yet take the wheel off and look at some shit. I wouldnt be hard to find out what is wrong.
Mike
