Old 11-21-2005   #1
SlowTsi
Took my shitbox to the dyno....
I wasn't sure where to put this so I threw it in here. Pulled 428whp/343wtq right off the street on 93 octane. I tried to throw in some c16 to push up on the limits of the stock 2g motor, but I ran into issues and it got too late. I will go back in a few weeks to throw down over 500whp. When i get my digi cam back I will thorw pics up of the sheet. Boost was 24 psi and timing was 10-11 deg. Car has typical bolt ons with hks 264/272, 2g magnus with 2g throttlebody, and DSMlink. The low torgue probably has something to do with the PT67 on a stock 2.0. It also explains why the stock clutch holds up to 428whp. The numbers were on a dynojet in 60-65 deg weather. Not bad for 116k miles.
New owner of ecoli's PT67 :) and Brian's 2g magnus :)
another 500whp stock motor 2g?? maybe a windowed block?? we will see :D
SlowTsi is offline   Reply With Quote
Old 11-21-2005   #2
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
Re: Took my shitbox to the dyno....
nice
what injectors are you running?
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
Old 11-21-2005   #3
SlowTsi
I am running fic 950s.
Old 11-21-2005   #4
Shotgun!
Totenritt
Shotgun!'s Avatar
That is truely awsome! Nice numbers for stock stuff.
Old 11-21-2005   #5
geez, t67 on a stock clutch? That'll last a while...
nice numbers, though! How much boost are you running on pump gas?
Old 11-21-2005   #6
SlowTsi
I am only running a tial 38 and it has a 1.4 bar spring. When the weather is cool (60s here in tx) it won't go lower than 24psi. So that is where it is at on the dyno. The clutch is actually much happier now with the laggier turbo. it only sees the tq number and this set up makes a good bit less torque than my stock manifold scm61. I has held 380ft lbs on the dyno, but did stink up the room. Future plans include my crower/magnus 2.4 with a polk head and comp 101400 cams. I will probably also switch to the race magnus or the AMS intake manifold and 75mm tb.
Old 11-21-2005   #7
I'm guessing you raised the rev limiter on your setup. That turbo would barely be making boost by 7500 on a 2.0.
Old 11-21-2005   #8
I had a PTE 3767 with a T3 .63a/r exhaust housing on it. With my 2.0 I had 30psi by 5500 or so, reved it to 8000 and made "550" whp on 110 octane, safe tune. I would put a good clutch in there asap, that will help a lot.
Old 11-22-2005   #9
I think this turbo was a T4 .81 though.
Old 11-22-2005   #10
SlowTsi
nah, i left it at 7500 since I knew it would hit peak before then. It doesn't spool till 6k on the dyno , but it is about 500rpm faster on the street. People still hit peak torque before 6k with a magnus
Old 11-21-2005   #11
dang. i need to get me a 2 liter.
Old 11-21-2005   #12
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
Wouldnt the low tq be because of the intake manifold too? I thought it helps out a lot with top end, and the longer runners in our stock manifolds help create more torque.
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
Old 11-22-2005   #13
When I sold it to him, it had a T4 .68, which is roughly equivalent to a T3 .82
Old 11-23-2005   #14
SlowTsi
Yep, its the .68 t4 with a p trim. I will probably upgrade to a BB one of these days. For now, all funds are being put towrds the shortblock.
Old 11-28-2005   #15
SlowTsi
Sheet
Finally got a chance to take a digi pic of the sheet. I didn't even relize it makes peak power at 7100rpm SMIM and big hotside for teh win!!1
Old 11-28-2005   #16
What did it make in SAE? STD is an old obsolete correction factor that is mainly used to over exaggerate the HP numbers when it is hot out.
Old 11-29-2005   #17
SlowTsi
SAE was 421 .xx for the highest pull. I only got this sheet form the shop. I have always heard that the STD inflates the numbers more, but it sure wasn't too much of a difference. Maybe it was the cool temps or relatively low output.
