Old 12-20-2005   #1
gonen60
gonen60's Avatar
head swaps
will a turbo head bolt up to a non-turbo head? I heard the blocks are pretty much Identical but wasn't sure if this would work. If so what are the benefits are far as power? or is there no gain?
gonen60 is offline   Reply With Quote
Old 12-20-2005   #2
Re: head swaps
A turbo head will not bolt up to a non-turbo head.
But the heads will interchange with the blocks.
Old 12-20-2005   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: head swaps
Ok, you need to post what year you are asking about. Also, why would you bolt a turbo head up to a non-turbo head? I'm guessing you ment bolt up to a non-turbo block?
1990-92 Turbo heads will bolt up to any 1990-94 non-turbo BLOCKs.
1993-99 Turbo heads will bolt up to any 93-94 block but need to be modified to fit on a 90-92 block to accept the larger head studs. 1990-94 all use the common 4g63 casting block. Turbo blocks just have a few more options.
95-99 non turbo's have a Chrysler 420a block. Completely different than the turbo motors so in return, no turbo head from a 4g63 motor will bolt up.
Originally Posted by shoutbox
Old 12-21-2005   #4
gonen60
gonen60's Avatar
Re: head swaps
Sorry I did mean the block. What type of power gain/benefits would I expect if I did this?
Old 12-21-2005   #5
Re: head swaps
Turbo cams in the NT would give you a slight gain. As for the actual heads...
Old 12-31-2005   #6
95tsi
95tsi's Avatar
Drives: a pos
Re: head swaps
I could wrong, but I thought I heard either the SRT4 head or the stock turbo setup bolts up to the Neon. I just cant recall which it was, had a friend talking about it a while ago.
Old 12-24-2005   #7
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: head swaps
is larger head studs the only thing that changed between 92 and 93 blocks?
Old 12-24-2005   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: head swaps
No... 93's have 7 bolt cranks, different crank case covers and oil pans. Piston squirters are different to - non removeable.
Old 12-24-2005   #9
s1ngletracker
Drives: A BMW
Re: head swaps
wait... it was in 93 that they switched to the 7 bolt motor?? I thought it was like 95...
Old 12-25-2005   #10
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: head swaps
It was actually April of 92. So some 92's have 7 bolt motors but its pretty rare to find one.
Old 12-26-2005   #11
Re: head swaps
The heads are pretty much the same, besides the cams.
Old 12-31-2005   #12
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: head swaps
Neither do... I have a friend doing a turbo setup on his Neon right now and he had to make adapter flanges for everything. The head didnt bolt up so he has to use his stock head and the intake and exhaust mani's have different bolt patterns.
