Old 12-20-2005   #1
Blew Up Drivetrain :)
1992 Tsi AWD 5spd
Wrote a Novel:
Under slight acceleration at about 70mph coming home tonight the car suddenly acted as if someone stepped on the brakes for about 1 second. I thought that was odd, and kept on going. Everything looked fine, good oil pressure, car wasn't running weird or making noises. Maybe one minute later the car started acting funny, I suddenly though my motor or turbo had gotten fucked I shifted and the clutch pedal stuck to the floor. I was freaking out, the car quickly came to a halt (felt like the wheels had locked up) as I tried to get it on the shoulder. My brother somehow thought we were headed for the ditch so he grabbed the wheel and put me back in the right lane of traffic, just as I pulled the keys to shut down the engine running. Stupid me, the wheel locked, so came to a stop in the right lane, engine still running, clutch to the floor, on a downhill slope not moving. While sitting still, there was some odd noises coming from the engine, so I hit the turbo timer and shut it down. My brother and I got our asses out of the car, and couldnt move it while it was in nuetral. The best part? The car was blocking right lane traffic in a blind banked corner right after a bridge on the highway. We were flagging people over, but still so many people almost smashed right into the parked car with the 4 ways and lights on. A car tailgating someone swerved around the cain front of them and nearly ran my brother and I over, we had to jump in the snow for our lives. We had called the police and the state police, and a trooper pushed it out of the way.
Got it home, jacked it up, tranny fluid everywhere. Took of the tranny crossmember, and there is a huge crack near the diff. (where the front axesl go into the tranny). Also, I noticed throught the flywheel inspection cover little copper wire shreds and clutch material. I pulled the clutch pedal up, the slave and forrk are still in teh depressed mode, and the slave has no presure (i can push it back with my fingers). I pulled the rubber fork boot, and three thin crunched metal peices tumbled out. The tranny fluid on that is all over the car is grayish with a nice metallic twinkle to it. Great
Any ideas? At first I thought maybe the transfer case locked up? Maybe the center or front diff blew up? About an hour prior, I did launch the car, spun them in first, shifted hard into 2nd and third. Car was working fine after that. I drove 15 minutes after that, shut it down for an hour, drove another 15 home and it blew up.
I just remembered, last time I was under the car, the trasnfer case was missing the lowest, most rear bolt. Looked like the threads were stripped on the tranny case. I thought 4/5 would be ok... but they put 5 there for a reason...
Thanks,
Kevin Swalchick
Old 12-21-2005   #2
Re: Blew Up Drivetrain :)
I'm gonna go with "blew the center diff which put a hole in the case causing the fluid to leak out, causing the transmission to seize, which caused excessive load on the clutch, which overheated and came apart, which caused damage to the clutch fork, which caused your ass to get stranded in a life threatening situation." Let me know if I missed anything.
Old 12-21-2005   #3
I'm with vicious on this one. Glad you're ok! Get iton the sholder next time, and smack your brother for grabbing the wheel! Look at the bright side, whenever you get it back together, you'll be able to put 5 bolts on the t-case!
Old 12-21-2005   #4
I'm pretty sure that sums it up I'm pissssssed, I just put in a new act2600lb, fork, fulcrum, and tob like 2000 miles ago. I'm gonna pull the tranny tommorrow; I can't wait to see what it looks like. I should have the case apart by then too hopefully. I'll post pics
Old 12-22-2005   #5
Pic#1-Clutch still on flywheel
Pic#2- Clutch Center
Pics#3&#4-Tranny case
Old 12-22-2005   #6
Old 12-22-2005   #7
Good kill, what in the hell did you guys do?
Old 12-22-2005   #8
Blew up the center diff. I'll take the case apart and see what really happened. And I was surprised the flywheel has no damage to it. The pressure plate cover is a little beat up on the outside, but Im sure I can get by with just a new disk. Oh and I was happy I pulled the tranny by myself in my garage in 3 hours taking my sweet as time.
Old 12-22-2005   #9
WHAT?!?!?!?!
That shit needs to go bye-bye.
Old 12-23-2005   #10
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Damn, that is fucked. Im with Vicious, from the first pic I would replace anything that disc touched.
Old 12-23-2005   #11
Being that the center Broke off wouldnt that make the disc just sitting there and not messing up the surfaces that it was on? It wasnt turning anything or being stoped it was moving freely, turning with the flywheel and PP. Just my thoughts.
Old 12-23-2005   #12
Can you say "heat damage"?
Old 12-23-2005   #13
Yeah, that was crossing my mind. Hmph. Stock clutch and my spare AWD flywheel might have to go on Whats the worst reusing the flywheel and pressure plate could do?
Old 12-23-2005   #14
Chatter, not hold under power, or worse. If there are heat cracks in those components they could spread. Which could cause them to fly apart at high rpm. Basically sawing your bell housing in half at worst and taking other components out with it.
It's hard to tell by the pics how bad the flywheel really is, but that pressure plate is "blued" pretty good. I suspect the flywheel is the same.
Old 12-23-2005   #15
CarPsyco84
CarPsyco84's Avatar
-Yeah, but when sumthing locks up in your tranny, and the input shaft locks... U still have a rotating flywheel and crank shaft, at like over 3k rpm... which would have enough momentom to rip the rivits right off the clutch....
-When in doubt, Moar RPM.
Old 12-23-2005   #16
Which is what happened.
Old 12-24-2005   #17
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
wait, maybe I'm missing this, so why did your tranny housing crack?
Old 12-25-2005   #18
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
The center diff wanted out. Fast.
Old 12-30-2005   #19
And also my input shaft (?) snapped.
