Old 01-04-2006   #1
CarPsyco84
CarPsyco84's Avatar
Preload/play for shimming tranny...
I have a 92 GVR-4 tranny and was wondering what the spec for the preload is in thousands on these for the tapered berings and what the spec play is for the straight ones on the front diff gear. like .003" or .005" I though but i dont remember...
-When in doubt, Moar RPM.
Old 01-04-2006   #2
Re: Preload/play for shimming tranny...
Hmm maybe bother Rick Shindley?
Old 01-04-2006   #3
Front Diff .002" - .006" Endplay
Output Shaft .0031" - .0051" Preload
Input Shaft 0.00" - .002" Endplay
Intermediate Shaft .0031" - .0051" Preload
Center Diff .0031" - .0051" Preload
Old 01-04-2006   #4
Center diff case end play
.0031" - .0051"
Center diff side gear end play
.0020" - .0100"
Front diff case end play
.0020" - .0067"
Front diff pinion backlash
.00098" - .00591"
Front Output shaft preload
.0031" - .0051"
Input shaft end play
0" - .0020"
Input shaft front bearing end play
.0004" - .0047"
Input shaft rear bearing end play
0" - .0035"
Intermediate gear bearing end play
.0004" - .0055"
Intermediate gear preload (shaft)
.0031" - .0051"
Transfer bevel gear set backlash (output)
.0031" - .0051"
Viscous coupling end play
.0039" - .0102"
*All from page 22B-6 of the service manual for the W5M33 transmissions.
I can also let you know what part number you need if you tell us available clearances, of if you have the manuals they are on pages: 22B-7 through 22B-11. Torque specs are on 22B-12.
good luck.
Old 01-04-2006   #5
LOL, shane already posted them! Nevermind then.
Old 01-04-2006   #6
CarPsyco84
CarPsyco84's Avatar
thanx shane, and swanny.
