Old 09-28-2005   #1
untouchable
untouchable's Avatar
Boost leak
I was curious if someone knew if there was an easy way to test for boost leak or does it have to be brought in?
untouchable is offline   Reply With Quote
Old 09-28-2005   #2
Re: Boost leak
http://www.vfaq.com/mods/ICtester.html
Old 10-20-2005   #3
quick2.4
Re: Boost leak
you can make a boost leak tester for under 10.00
a coupler an a pcv fitting with an air line fitting in the end of it an hook it up to the turbo intake with 20-30 psi an plug it in an listen an you will ! find what your looking for
quick2.4 is offline   Reply With Quote
