Old 10-17-2005   #61
Onefast99gsx
Re: Sealed the Deal on a Talon TSi AWD
Yeah, listen to JET. Back about a year ago I was gonna get one of those 57 trims and more than one person steered me away from it. Compare the compressor maps. The 50 trim has a much better map. Don't compare the 50 vs 57 numbers themselves. Naturally you'd think (57), well that must be a bigger and better turbo. Not so true. I bought a PTE 50 trim and I'm MORE than happy with it. I went 12.44 with it on Saturday at ONLY 19# of boost. Had I done my homework that day and troubleshot a problem, I should have easily been in the 11's with 25-26# of boost. By the way, that was on a stock 2g head, except for 272 cams. Only the rough casting was ported. Nothing was hogged out. Start with the smaller mods first like some that JET mentioned in the list. Don't get a big turbo and try to make it work with what you got. You'll be disgusted.
Old 10-17-2005   #62
I went 123 mph on 26#'s with a PTE 50 trim and a bone stock head and intake manifold. She still had a lot more in it, but the engine was crankwalked.
Old 10-18-2005   #63
Addicted2DSM
Addicted2DSM's Avatar
Send a message via AIM to Addicted2DSM Send a message via MSN to Addicted2DSM Send a message via Yahoo to Addicted2DSM
-Bored .40 over
-Removed balance shafts
-ARP Main, Rod, Head bolts
-Stock rods with 95 pistons
-Mitsubishi Metal HG
-Stock head with HKS 264/272 cams
Bolt ons:
-Calsonic fmic with HKS ssqv bov
-Apex-I turbo back exhaust
-walbro 255lph fuel pump
-Fluidyne radiator w/flex-a-lite fans
-Energy Suspension poly motor mounts
DriveTrain:
-TRE spec trans
-11k since rebuild
-Double syncro 2nd
-steel rails/ forks
-4 spider center diff w/ roller bearing
-10% taller 5th gear
-ACT street disc w/2600lb pressure plate
-ACT xACT streetlight flywheel
-SS clutch line
- 4 bolt rear diff
Suspension/Wheels:
-Energy suspension sub-frame bushings
-KYB AGX struts w/ Ground Control coilovers
-RM rear sway bar
-RRE front strut bar
-18x7.5 Rays G-Games 57W’s w/ 225/40 dunlop FM901’s
Stoppers:
-Stoptech front big brake kit 2k on it
-ST-40 calipers w/ 328x28mm rotors
-Power slot rear rotors
-SS lines
-2g master cylinder
Misc:
-Eprom ecu
-VIS oem cf hood
-evo 8 shift knob
-MOMO champion steering wheel
-Razo titanium pedals
-Extreme Motorsports short shift kit
-Bride Brix II reclinable seats in black suede
-AEM Gauge-Type Wideband UEGO controller
thats whats in the car right now. Just talked to the seller, he hasn't looked inside of the ecu, if he had the car running he would of been selling for 8 grand.
Looking for a 1g AWD
"What Doesn't Kill You, Makes You Stronger"
Addicted2DSM is offline   Reply With Quote
Old 10-23-2005   #64
so..any word on the car?
-A. Swift
Old 10-23-2005   #65
I think a lot of people will be envious of you if you get that car. It's nice, and has some expensive parts very few of us have, but want If you get it, I hope you get it fixed easily. But I agree with some other people, sounds like you have a bit more reading and listening to do. But who the hell am I to say anything.
Old 11-08-2005   #66
Addicted2DSM
Seller fucked me over and sold it. He's been pretty shady as well, my friend was supposed to look at it and was never able to reach him on the phone. But whatever man I bet a 16 year old kid bought it and will deal with the headaches now. Still on the prowl for a car. I have 4k in my pockets ready to buy if the deal is good.
Old 11-08-2005   #67
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I probably wouldn't buy it to get it running for the fact that he says you couldn't have a mechanic look it over before buying it. That alone makes me think the motor and tranny are trash or the electrical is really messed up. I would of only bought it to part out. It was over 1600 miles away from minnesota though.
7/25/09
Old 11-08-2005   #68
Thats probably for the best, that car sounded a bit shady as well .
Old 11-08-2005   #69
Addicted2DSM
Im thinking about RK's GST right now. First give a 6 bolt swap if it hasn't been done.
Old 11-09-2005   #70
IndiEP
Tha MIG Masta!
IndiEP's Avatar
Thats the best thing that could of happend to you. A good seller will not hide anything and stand behind any work they've done.
Austin
Old 11-10-2005   #71
Addicted2DSM
my friend just hooked up me up with a 90 Talon AWD in pristine condition with a fresh Cyclone motor and bolt on galore for 5k
Old 11-10-2005   #72
IndiEP
Tha MIG Masta!
IndiEP's Avatar
you can't say that and not post pictures!
Austin
Old 11-11-2005   #73
Addicted2DSM
Once I get pics I intend to post them up. Man he's getting her hooked up big time for me, this car is going over 5k. Im supplying SAFC II,720cc injectors, Turbo XS dual Stage MBC. Right now Im in Japan waiting to get discharged from the military then I'll head to SoCal to pickup my car and hang for a few days then head to Arizona.
