Old 01-03-2004   #21
Originally posted by CUSTOMDSM@Jan 1 2004, 05:43 AM
Hey Andy now you just need a 2.4 or some NOS to spool that big fucker. :bounce:
Yea, that thing is so laggy it's insane. Definately not a streetable 2.0 turbo.
Old 01-03-2004   #22
JDM
None
Drives: A car
Send a message via MSN to JDM
Jesus Christ Nash... I've ordered pizzas smaller than that..
wow. :bowdown"
None
Old 01-04-2004   #23
copper_gst
copper_gst's Avatar
Damn thats huge. Definitely a great addition for under the hood, if it fits!
copper_gst is offline   Reply With Quote
Old 01-04-2004   #24
Oh, it fits, and sounds like it belongs on a semi. :dsmrule:
Old 01-04-2004   #25
Nash
Nash's Avatar
It fits,it's laggy, but I still love it. Just the sound when it starts spooling is awesome.
Old 01-04-2004   #26
Nash
Nash's Avatar
The turbo isn't that laggy. I was hitting full boost, 21psi, right around 4600rpms on the dyno. And I wasn't going to post up the dyno results, but here they are.
This pump gas, 21psi, creeping to around 25 by 7500.
Old 01-04-2004   #27
If sound is what you need, you should have gotten one of these and saved some $$$. :bounce:
J/K
Old 01-04-2004   #28
25psi is some high boost for pump gas, what was the timing set at?
Old 01-04-2004   #29
It's still creeping in the upper RPMs. We didn't hit the 25 psi until right at 7500. I was joking about the lag also. It spools much faster than I would have thought. At peak HP I am not sure what boost we were actually at. We had the base timing set at about 0.5 degrees. So we were running around 13 to 18 degrees of actual timing depending on the RPM. The stock timing map trails off in the very top RPMs where we hit max boost. It also starts off low, so we didn't have any problems in the mid-range. We just had to be most careful in the 6000-7000 range where it wants to run the most timing. The creep made tuning a little bit of a pain, hopefully that can be fixed. Should get more interesting once he gets his sheetmetal intake and EPROM ECU, then the power should keep climbing some and we should be able to modify the timing tables in the ECU to what we want.
Old 01-04-2004   #30
Sounds good :dsmrule:
Old 01-04-2004   #31
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Now you can run your 11's on pump. :woowoo:
Old 01-04-2004   #32
Congrats on the 400 andy. thats badass, wanna trade cars? LOL.
Old 01-05-2004   #33
If you had Andy's car you wouldn't know what to do...
1) Uber amounts of power.
2) Lack of bling.
3) A clutch pedal and manual shifter.
Just playing, Tom... You'll be above stock power some day.
Old 01-05-2004   #34
Nash
Nash's Avatar
I hope so.
I just really want to get the damn creep fixed. It seems to creep alot more on the street then it did on the dyno. Hopefully the having Mike port the turbo and o2 get's rid of it. If not I'll just have to break down and get a 3" down pipe, and hope that helps.
Old 01-05-2004   #35
adam_murphy
Send a message via MSN to adam_murphy
nash thats F***ing insane!!!!
i bet we'll see huge numbers from you in 04
good luck!
2002 GTP - 12.9@107.5
adam_murphy is offline   Reply With Quote
Old 01-05-2004   #36
Nash
Nash's Avatar
good luck!
Thanks, but the really props need to go to Shane at Elite. He's the one who get's the power out of all my set ups.
Old 01-05-2004   #37
Damn, 400+ on pump, very nice. :bowdown"
Now let's see if Shane can beat that with his little turbo.
Old 01-05-2004   #38
Fuck turbo. All-motor baby!
Old 01-06-2004   #39
Nash
Nash's Avatar
No more boost creep!
