Old 12-11-2005   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
removing abs
Now that the engine is out. I'm about to start removing my abs on my Talon awd. I've read a couple FAQs and they all say I need a non-abs proportioning valve & 4 brake lines. I'll post up and ask here, does anyone have a donor car with the lines & valve? Or point me to where I can find them locally?
Old 12-11-2005   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: removing abs
We gave some we had to jakey for free. You could look in a junk yard to try and find some that aren't rusted out. I thought I heard they don't make one of the lines you need anymore so if you cant find one, you might have to make it.
7/25/09
Old 12-11-2005   #3
Re: removing abs
The proportioning valve is no longer available. I believe the lines are no longer available as well.
Old 12-12-2005   #4
Re: removing abs
Yeah, but they are on parts cars and in junk yards in good supply. I got mine up at John's in Blaine years ago.
Old 12-12-2005   #5
Re: removing abs
Does anyone know of a tech article anywhere describing the removal of all 1G abs-related electronics? I'm sure if I RTFM I could figure it out but it's always nice to have an easier method.
Old 01-02-2006   #6
Re: removing abs
Why do people remove the ABS on these cars? I haven't ever owned a 1G with ABS.
Old 01-02-2006   #7
acidrumz
Send a message via AIM to acidrumz
Re: removing abs
yes you will need the non-abs proportioning valve. you can get both of what you need at the junkyard (upullrparts). that valve and the 2 front brake lines to the front rotors. you don't need to replace the rears. that's it.
later.
acidrumz is offline   Reply With Quote
Old 01-02-2006   #8
Re: removing abs
Weight
Old 01-02-2006   #9
Re: removing abs
Weight
Oh pssh, just make more power to make up for it.
Old 01-02-2006   #10
Re: removing abs
I deleted my abs in the stealth. Similar setup to the dsm's. I re-used my prop-valve, and just made a few lines. Its pretty easy to do if you know what you are doing.
That being said, the EASIEST is to get the bolt-in (N/A) solution.
Old 01-02-2006   #11
Re: removing abs
I don't want to do it because of weight, but to get all the ABS shit out of my engine bay.
