Old 01-07-2004   #1
Iceman
I need the pythonern (sp) tubing for my autometer boost gauge. Does anyone have any or know where i can get some?
Old 01-07-2004   #2
Checker or Napa or Red Roster. Even Home deppot has enough, and if I remember right I have some I could get ya. I will check in the morning.
Old 01-07-2004   #3
Iceman
Home depot huh.... Ill go there and check... or napa i sappose...
Old 01-08-2004   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Not to start a war here, but if you want to get something that will last, go to a parts store (Checker, Napa, etc.) and buy a copper tubing kit for guages. You have to be careful putting it in so you don't kink it but it stands up better than the plastic. You can form it easily and it stays where you put it. It won't crack in cold temps either. I've used it on my oil pressure guages in the past and it's the only thing I use on my boost guages. It comes with the compression fittings and everything.
Just my $0.02....
Old 01-08-2004   #5
john
Business as usual
john's Avatar
He needs 1/8 inch to connect to the boost gauge. hard to find coppertubing in 1/8 inch along with poly hose. BTW, the flexible nylon hose will not work for this application. My boost gauge uses the same shit. My gauge came missing the inserts. After searching everywhere (home depot, menards, local hardwar and plumbing stores) I decided I would have to make my own.
if nobody has any extra or a place to get any, I could probly make it work for you James. Stop up at my work sometime and I will see what I can do.
97 Viper GTS
Old 01-08-2004   #6
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
If you buy a copper tubing kit for guages, it is 1/8th inch and has the compression fittings (nuts and inserts) in the pack. It has a thinner wall thickness than regular 1/8th copper tubing for better response at the guage. Its cost is under $10 and well worth it. I have bought these from auto parts stores for both of my guages (boost and oil pressure) and have never had a problem with either.
Also, any hardwarre store will have the inserts. Ace, Home Depot, Lowes, Menards, etc. They all have them.
Old 01-09-2004   #7
I have looked at both Menards and Home Depot and as far as nylon tubing (the Autometer stuff, nylon or whatever it is) the smallest they sell is 1/4", Autometers use 1/8". Maybe the stores I looked at where just out, but I didn't see empty shelf space for the 1/8".
Old 01-09-2004   #8
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
That's why I say go to an autoparts store and buy the kit. It's cheap and easy. I just don't put much faith in the plastic tubing crap. That's why I go with copper tubing.
Old 01-10-2004   #9
Iceman
I ended up getting it and bending it.... very easy to do escally if it comes in a little wound up circle of it. The kit i got from checkers only gave me 6 feet which to some is to little. Anyway the car is gone now but thanks for all the input. I ended up leaving it off for him.
Old 01-10-2004   #10
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
How much was it? I need to get a kit for Terina's car now that we finally got her boost guage.
Old 01-10-2004   #11
Iceman
6.50 or so i belive... comes with fittings and all that do da... I thought it sucked though and won't be buying it agian.
Old 01-10-2004   #12
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
It is a little tough the first time but it is beneficial in the long run with durability.
Sorry to hear you had a bad experience with it. It takes patients but I think it's well worth it. Did you have problems uncoiling it or what? Or was it a problem with running it thru the engine compartment and under the dash?
Old 01-10-2004   #13
Iceman
The problem i had was uncoiling it... Its all wound up in a little package and the thing just refuses to come unwound... Anyway it would of worked if yes i had more patients. But it was cold and yada yada yada.... Good luck with it.
Old 01-10-2004   #14
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
I kinda figured that was the problem. Sorry to hear that.
