Old 02-08-2006   #1
ther1pper
ther1pper's Avatar
Send a message via AIM to ther1pper
white smoke and lots of it!
well i was driving and floored it pretty hard in first gear and then i heard a loud pop and the next thing u know white smoke is pileing out of my exhaust, the sides of the hood, and even into my car. first thing that came to mind was a blown turbo. cher was over the other day and we took the intake off and looked at the turbo and the wheel had very little play back and fourth and thats it so i dont think that, that could cause that much smoke. cher said it could posably be a blown head gasket, well befor i go on, i can drive the car fine but once i build boost smoke just piles out, well i can build boost fine in first gear w/out smoke, but when i switch to anohter gear it really piles out. so cher said to run a compression test. so today at work i ran a compression test and it was fine, i think that max hd it went to was 4. iam kinda stumped, and not that knowledgable, and iam goin to florida on the 27th of this month, so im trying to get my car running good. help is needed pls.
ther1pper is offline   Reply With Quote
Old 02-08-2006   #2
Enes
Enes's Avatar
Re: white smoke and lots of it!
damn, now i have to get advil first before i answer...
Old 02-08-2006   #3
Head gasket is blown. Now use your shift key.
Old 02-08-2006   #4
The white smoke you see is probably coolant.
Old 02-08-2006   #5
ther1pper
ther1pper's Avatar
Lets please stick to responses that will help my problem.
Old 02-08-2006   #6
blageo23
AWD4G64
blageo23's Avatar
How could it be the HG if the compression is good? Would the seals in the turbo blown cause shaft play? If not then maybe the seals went and you are leaking the coolant into the exhaust.
Old 02-08-2006   #7
Sounds like a blown headgasket that is only leaking under a load/boost.
Old 02-08-2006   #8
Like Hughie said, cranking compression is minimal, ~150psi, cylinder pressures under boost are MUCH higher. The fact that you saw smoke from under the hood suggests something else though. Check all hose connections for starters, also pull the plugs and see if they're wet.
Old 02-08-2006   #9
blageo23
AWD4G64
blageo23's Avatar
Remeber when we were driving it joe, I believe the block looked wet and it looked as tho oil was coming from the turbo.
Old 02-08-2006   #10
Why don't you post up a mod list before we go any further.
Old 02-08-2006   #11
Try a cylinder leakdown test. I would also bet the headgasket is lifting under load.
How much boost were you running? What sort of tune? Do you have head studs?
Old 02-08-2006   #12
ther1pper
ther1pper's Avatar
apexi 2.5 in downpipe
apexi n-1 exhuast
greddy type-rs bov
2.5 in hard upper ic piping
greddy oil catch tank
elite manual boost controller
safc-1 (blue screen)
Im pretty sure thats it off the top of my head.
Old 02-08-2006   #13
Hows the catch can looking? Full?
Old 02-09-2006   #14
ther1pper
ther1pper's Avatar
like half inch full
