Old 03-15-2006   #1
2.3L vs 2.4L
Which is better, and why? 6 bolt 2.3L stroker vs 6 bolt 2.4L (g4cs)
I am considering my car's future; I'd like a GT35R.
Old 03-15-2006   #2
Re: 2.3L vs 2.4L
A 2.3 looks like a stocker, as if anybody could actually tell anyways. Other than that, a 2.4 is easier to build, and gives you the extra .1L of displacement. Seems like a no-brainer to me. Either will spool most GT35R's easily.
Old 03-15-2006   #3
Re: 2.3L vs 2.4L
i like the 2.4Ls extra deck height. more deck height = increased rod ratio = less cylinder side loading = less wear.
not like it really matters, i don't think the avg lifespan of a 2.3/2.4 is 100k miles in built form.
Old 03-15-2006   #4
Re: 2.3L vs 2.4L
The reason they don't last isn't because of them being a 2.3 or 2.4, its because usually they are pushing a shit load of HP. I bet if you put a 14b on it and ran 11psi with minimal mods it would last a long time.
I would definetly do a 2.4 though, cheaper, easier.
Old 03-15-2006   #5
rst95eclipse
Re: 2.3L vs 2.4L
A 2.4 is cheaper and easier, however I have no clue what it takes to mate a 1g or 2g head to a 2.4 block. A 6 bolt swap is well documented, which would give me a better piece of mind. I don't think a .1L difference would mean too much in spooling anything. You'd see it something like 150 RPM sooner, but that's what nitrous is for.
Old 03-15-2006   #6
Re: 2.3L vs 2.4L
A 2.4l will be no different than a 6 bolt swap except for the timing belt. All mounts are the same. You may have to tap the knock sensor hole, that should be the extent of it.
Old 03-15-2006   #7
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Re: 2.3L vs 2.4L
So there is no huge performance gain from going to a 2.4 over a 2.3?
99 GSX- Sold
03 Evo- More than stock.
-ATC Productions-
is dead.
I hate Mitsubishi.
Old 03-15-2006   #8
Re: 2.3L vs 2.4L
The 2.4 is easier, cheaper, and should be more reliable. Performance should be similar.
Old 03-15-2006   #9
SchuttsR1
Yes, I am inbred
SchuttsR1's Avatar
Re: 2.3L vs 2.4L
The extra displacemet will give you a little more tourqe.
special:)
SchuttsR1 is offline   Reply With Quote
Old 03-15-2006   #10
Re: 2.3L vs 2.4L
I usually use a set of ARP headstuds.
Old 03-15-2006   #11
Re: 2.3L vs 2.4L
The displacement advantage in a 2.4 is actually from the bigger bore (since they use the same crank). A bigger bore will affect HP more than torque, where the stroke affects torque more than HP. So, theoretically, the 2.4 will make slightly more HP and basically the same torque as a 2.3l.
Old 03-15-2006   #12
rst95eclipse
Re: 2.3L vs 2.4L
Don't you have to bore it out when you're doing a 2.3? I believe that a 2.3's bore is 88mm. Maybe you have it switched around. More torque than HP.
Well there's po-folk like me that doesn't have the cheese to get my hands on that hardware.
Old 03-15-2006   #13
Re: 2.3L vs 2.4L
LMAO!!!
Thats awesome.
Old 03-15-2006   #14
Re: 2.3L vs 2.4L
No, its a 88mm stroke for a 4g63.
It is a 100mm stroke for a 4g64.
The bore is 85mm on the 4g63.
The bore is 86.5mm on the 4g64. (thanks shane for the correction!)
The srt-4 stuff, just for fun:
101mm stroke w/ 87mm bore. They call it a "2.4" that revs to a blistering 6000rpm (factory redline).
Bore size=horsepower.
Stroke is usually related to reving capiblities, powerband, and torque.
The 4g64 crank in the 4g63 isn't worth it in my honest opinion. Just buy the correct block to begin with.
Old 03-15-2006   #15
Re: 2.3L vs 2.4L
what you are saying doesnt' make ANY sense. a 2.3 is composed of a standard run of the mill 4g63 block that comes in any dsm, and a 100mm crank out of the 4g64/g4cs motors. the stock bore on the 4g63 is 85mm, and that is the end of that. boring it out to 88mm would leave the sleeves MIGHTY thin, which isn't in your best interests.
for future reference the 2.4 blocks have a stock bore of 86.5mm.
Old 03-16-2006   #17
Re: 2.3L vs 2.4L
sigh.
You switch the cranks, thats the easy part.
Weisco makes shelf stock pistons for it.
You need to clearance the mains and the block for the crank to rotate.
It is not that "easy" if you have to ask about it, in all honesty.
Old 03-16-2006   #18
Re: 2.3L vs 2.4L
Could someone put a built 2.4L in a completely stock car with no ill effects?
Old 03-16-2006   #19
Re: 2.3L vs 2.4L
No. The larger motor will consume more fuel. Your turbocharger will also hate life.
Old 03-16-2006   #20
Re: 2.3L vs 2.4L
there is a kid down here with a built 2.4L in a fwd 2g with the friggin t25 on it, haha. BOOST AT IDLE FTW!!
