Old 03-16-2006   #1
BOVADDICT
is in debt neck deep
ok wtf?
Alright 95 tsi awd.
JUST REPLACED 2 DAYS AGO!!!
new turbo, new fmic, maft setup, new walbro 255 pump, new aeromotive afpr, new pte 680cc injectors, new crank sensor, new timing belt, new water pump, new thermostat, flushed radiator, crank walk tested(and its fine), compression tested (its fine).
Other mods, turbo xs mbc, ghetto test pipe with stock exhaust and a muffler, And thats all I can think of that would affect this problem..
SO.. my car sputters.. Since I bought it.. The other day it sputtered and then backfired a lot then boom! it blew up and I got a new crank sensor and all that crap. So today I got my car back.. And I go to boost and I hit 10psi and it sputters then takes off again.. WTF?!?!
Is this is aboost leak? If so it can only be the intake manifold right? Thats all thats after the maft...
Or is it my exhaust not functioning correctly? Hole in it? I DUNNO!?!?
Any input? Cause this honestly has been my only goal to fix this damn sputtering and its still here thousands of dollars later...
galant vr-4 #46/1000 16g and supporting
240sx track
BOVADDICT is offline   Reply With Quote
Old 03-17-2006   #2
Re: ok wtf?
I don't know exactly, but have you checked the spark plugs and the their gap? Do you need wires? (if they are old or really cheap ones you might need to replace). Keep it simple, then work your way up.
If you're so worried about boost leaks, make yourself a tester. Very easy and cheap to make, I'm sure there are instructions online somewhere. Try Vfaqs!
What are you using to control the injectors? the MAFT? Is it setup right?
Old 03-17-2006   #3
BOVADDICT
Re: ok wtf?
yes its sputtered sicne before I had the maft or injectors.
They are nkg cold plugs and nice wires. ll try replacing them..
Any suggestions?
Ill just bring it to lse if I cant figure it out.. Im tired of this sputtering!!
240sx track
Old 03-17-2006   #4
Re: ok wtf?
Could be a ton of things man, try to provide more info. Does this happen all the time? And what happens when sputters? Do you have a decent tune on the car? If so, what A/F ratios are you seeing during these periods?
Even though you have a MAF-T in blow-through, you could still have a ton of leaks (trust me, I know from experience):
-TB Elbow
-TB to Manifold
-Manifold to Head
-Any of the injector seals
-Any of the vacuum lines coming off of the intake manifold.
Do a boost leak test & then do it again. Once you've completely eliminated it from the equation, just do it again, trust me.
Old 03-17-2006   #5
Re: ok wtf?
Like we've all stated about 100 times, get some new NGK BPR7ES plugs and make sure to gap them correctly at .030" and get some new quality wires. NGK, Bosch, Accel, Taylor, etc. all make nice wires. Also, do a boost-leak check. If you don't know how bring your car to a local performance shop and throw $$$ at them. You've spent all this time and money replacing the complicated shit when you should have been doing the cheap and simple stuff from the beginning like we've all recomended. Why ask questions if you disregard the answers?
Old 03-17-2006   #6
95tsiAWD
95tsiAWD's Avatar
Re: ok wtf?
check engine light on? if so what codes are coming out
In certain extreme situations, the law is inadequate. In order to shame its inadequacy, it is necessary to act outside the law. To pursue... natural justice. This is not vengeance. Revenge is not a valid motive, it's an emotional response. No. Not vengeance. Punishment.
95tsiAWD is offline   Reply With Quote
Old 03-20-2006   #7
pinkys10
pinkys10's Avatar
Re: ok wtf?
Dont Fuck With My Brother Hughes! Ill End You All!
WE DUMB....DUMB AS HELL!
pinkys10 is offline   Reply With Quote
Old 03-20-2006   #8
Emcee gsxtc
Emcee gsxtc's Avatar
Re: ok wtf?
That is my favorite answer! When in doubt, I let people who actually know what they are doing fix what I thought I fixed. Good Luck!
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 03-24-2006   #9
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: ok wtf?
Probablly have it fixed by now, but my car would boost fine 2 like 3000-3500rpms bost gauge would sputter then all the sudden boost would kick back on it ended up being my spark plug wires....
Old 03-24-2006   #10
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Re: ok wtf?
that is a bid problem half the time WIRES AND PLUGS! got to have the ngk 7es best plugs ever!!
96 Gsx Awd is offline   Reply With Quote
