Old 06-19-2006   #1
blageo23
AWD4G64
blageo23's Avatar
NEED HELP FAST! Oil Pressure Switch
I put in my new alternator and I ended up breaking the Oil pressure switch(alternator sliped and fell on it). The end where you hook up the wire came off. So I glued it back together for temperary fix so I could drive it. Is this safe to do? Also under my car was a small spring, Does that go in there? What exactly does it do?
Old 06-19-2006   #2
Re: NEED HELP FAST! Oil Pressure Switch
As far as I know the switch only turns the idiot light on/off on the dash for low oil pressure, does nothing else to the car.
Old 06-19-2006   #3
yup, you should be fine. Just get a new sending unit & you'll be fine.
Old 06-19-2006   #4
get an aftermarket gauge that actually reads better then the stock one..i wouldn't even mess with that stock one. But yes, it only turns the light on and off, based on the pressure the sending unit sees.
-A. Swift
Old 06-19-2006   #5
blageo23
AWD4G64
blageo23's Avatar
But wouldnt a aftermarket guage go where the "oil pressure guage" unit is(the bigger of the 2 on the oil filter housing)? Thanks for the help guys!
