Old 01-25-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
a stupid question but i was just wondering.
when does full boost kick in for the evo8?
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 01-25-2004   #2
When you push the gas pedal down.
Old 01-26-2004   #3
HHAHAHAHAHAHAHAHA
Old 01-26-2004   #4
it kicks in pretty damn quick, i don't know a RPM number off the top of my head, but way quicker then most turbos spool up on dsm's. I swear it feels like the 16g's on those cars spool up like a t25
Old 02-05-2004   #5
Sleep-ez
Guest
Tournaments Won: 6
Posts: n/a
crap we have the same avatar
anyways, full boost is pretty low because the turbo spools so fast but the boost goes from 19psi at lower rpms to 16 at higher. its something that mitsubithi did to conserve the life of the turbo and the motor. if you want it to stay at 19psi you need to by any boost controller, as long as you dont adjust it it will stay at 19psi. dont turn up past 21 psi or oyu wil hit fuel cut.
Old 02-05-2004   #6
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
I thought I had read in Mitsu's Evo8 brochure that full boost was at about 3900rpm. Could be off, but that's what I recall.
Old 02-05-2004   #7
FORSFED
Sorry it's just a guess, but I would think by about 3k or close to it. It's supposed to be a 16g equivalent or so and those spool between 3-3200 rpm's. 3900 is way to high.
Old 02-05-2004   #8
I was thinking more like 2800-3000rpm.
Old 02-05-2004   #9
Its no 16g equivalent. Maybe the flow, but the spool on those things is like a t25. Id say more like 2900 then 3900
Old 02-05-2004   #10
john
Business as usual
john's Avatar
definitly not 3900, a 50 trim should spool by then. With any 16g sized turbo you shouldn't have to worry about lag at all. They are too small. Hit the gas and you have boost.
97 Viper GTS
Old 02-06-2004   #11
SuperSleeper
Here it is: Peak boost at 3500rpm.
http://features.evolutionm.net/article/lanevo/20/4
Old 02-06-2004   #12
It has a 16G.
