Old 08-05-2006   #1
Bigger and better
So who says dsm's aren't reliable? All you need is same-day parts available!
My bastard 20g blew up on my way into work this morning, and I want to give a very special thanks to James (SlowBubbleCar) for taking the time to help me get my ride back on the road again! I limped the car back home @ 5:15pm from the Applebee's on Hwy100 & Duluth St. At 6pm, I have all of the fluids drained and the manifold off. Break for dinner to let the turbo cool down before I yank it out, and then head down to Hopkins to meet up with James to pick up my 'bigger and better.'
Yes he had already listed it for sale, but it was still bolted to a car. James took the time to help me by yanking the turbo off for me as soon as he was off work, even though he had other stuff to do. I show up at about 8pm & we finish up yanking off the turbo & shoot the shit for a wee bit.
I b-line it home, stop at DQ to keep Anna happy (and me, I guess!). 9:45 I have the bastard 20g pulled, and by 11:30 I have my new little hamster wheel installed, a GT3582RLE-M (?) I think technically this should be called a GT3582RLSM because it has the 4" inlet w/ ported shroud, but who gives a flying F, this thing is big and bad ass!
(yes, turbo helped with the install!)
running like a champ!
So of course, I ran into some coolant line leakage (my bane when it comes to turbo installs, I have no idea why) so I ended up dinking for an extra 2 hours on the thing. I ended up getting it all buttoned up, and I'll take it for a test drive tomorrow!
Old 08-05-2006   #2
Re: Bigger and better
More misc pics here, if anyone's interrested:
http://www.scheides.com/gallery/gt35r
Old 08-05-2006   #3
Shane55113
Now 20% less Racist
Shane55113's Avatar
Sweetness and props for the fast work. I hate the turbo lines, if i had it my way I would use quick release valves like on air compressor tools.
Old 08-05-2006   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
internally gated 35R? Hopefully it doesn't creep too bad.
'04 Honda Ricer: stock
Old 08-05-2006   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
The previous owner didn't have any creep issues with it at just below 30psi. He said it might have spiked for a second but that was it. I bolted it up and never used it.
7/25/09
Old 08-05-2006   #6
Drives: 98 iVTEC
Well yeah... try running 15-20 psi and it'll probably creep to 25 or something.
Old 08-05-2006   #7
Yea, frankly I'm quite interrested in how low it will go as well. I'm sure itwon't hold up top like an externally-gated one would, but with the big flapper, the cut exhaust housing, and my LIPP o2 housing, it's going to be interresting!
Old 08-05-2006   #8
blageo23
AWD4G64
blageo23's Avatar
As soon as you said that you were buying a turbo in the for sale ads I knew you were going for that turbo. Good job man hope it works out for ya.
Old 08-05-2006   #9
Pretty bad-ace, man. Way to repair! I can't wait to hear what you can do with that thing.
Old 08-05-2006   #10
I agree with andrew. Congrats on the fast swap, a real cool story TGIF huh?
Old 08-05-2006   #11
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Thats awsome. good choice in turbos. My Internally gated 61 creeps to about 22psi above 6000. With the LIPP housing you'll probly be OK. Get that thing out on the road and give us some reports.
11.35 @ 120mph
Old 08-05-2006   #12
curt_gendron
curt_gendron's Avatar
Great story Chris!! That was a fast turn around. I guess we'll be able to see this monster at the Cookout. W00t!
later,
Curt
Minnesota 3/S
Old 08-05-2006   #13
So how is it?!?!?!?!?
Old 08-05-2006   #14
Working this morning, I'll have it on the road in a while
Old 08-05-2006   #15
Nice! Less work and more play.
Old 08-05-2006   #16
Black97civic
35mpg
Maybe the DSM gods are smiling down on you or something, because without your old turbo taking a crap on you, you wouldn't have gotten this turbo, and it just happened to be for sale locally.
Good to see that everything worked out well
Old 08-05-2006   #17
Well said! I'm on the home stretch here, but I need to leave for a wedding @ 5pm...we'll see if I get to take it out yet today! (crosses fingers)
Old 08-05-2006   #18
Just took the car out for a spin. The first few trips around the block i had coolant leaking out of the coolant feed line (again! Ahh!). Checked the coolant level, all is well. Then after getting back out after a 10 min drive, no coolant leaking anywhere, and the coolant level is ok!
She definitly needs some tuning time. Not sure my 650's will be up for the task past pump gas, but we'll see. Second gear pulls yield max boost pressure of about 17psi, and boost onset occurs somewhere around 4500 rpms. There is a ton of power in this turbo, the sheer size of the thing makes me just giggle!
Old 08-05-2006   #19
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
You will definately need bigger injectors. I have some 780's that I was going to use for that turbo.
7/25/09
Old 08-06-2006   #20
Shane55113
Now 20% less Racist
Shane55113's Avatar
lol, your the "go to guy" round these parts.
