Old 08-05-2006   #1
mustang throttle body
i found a good deal on an intake with a 75mm mustang throttle body on it.
do these have a similar 5volt tps to the ones dsms already use?
would i be able to run this on a stock ecu (dsmlink) car?
Old 08-05-2006   #2
Re: mustang throttle body
i didn't mean to make two of these threads. Mods please delete one.
Old 08-05-2006   #3
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Don't buy it if it's got an Accubreak on it.
'04 Honda Ricer: stock
Old 08-05-2006   #4
Accufab actually redid their shafts about a year ago. It should be fine if it has the new one on it.
Old 08-05-2006   #5
Man, my Accufab 75 has been ok for long while now. But everytime I here about them breaking, my brain hurts. Do I risk keeping it, or do I buy a different one?
Sorry about the Hijack, but yeah, I think the tps is similar, but do not know if it'll work with the ecu/link..
Old 08-05-2006   #6
Yes, the TPS works fine, you lose the ISC though. If you have an old Accufab, they will upgrade the shaft for $75.
Old 08-05-2006   #7
Don't get the Performance Products one, mine leaks at the shaft seals and whistles at idle. They said they'd replace it no problem, but I already welded the DSM pulley to the shaft. I don't use any kind of ISC, mine idles perfect at 1500 rpm after about 5 minutes.
Old 08-05-2006   #8
Is that your poor man's cruise control?
Old 08-05-2006   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
What is wrong with not having to use the gas when starting from a stop?
7/25/09
Old 08-06-2006   #10
Cool, good to know, I'll have to do that.
Old 08-06-2006   #11
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
Just thought I would add that I used an accufab for quite awhile, no problems.
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
Old 08-06-2006   #12
Still gotta rev it up. A big turbo and a twin disk doesn't make for silky smooth starts.
