Old 08-16-2006   #21
Re: I give up...
Yeah its still the ACT 2100 Pressure plate that was on when the problem started.
Old 08-16-2006   #22
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: I give up...
i'd throw a stocker on there or something if you have one lying around. Not really worth buying a new one unless you know its bad.
Style's automotive engineer
Old 08-16-2006   #23
Re: I give up...
If the pressure plate is bad the fingers on the front should be visibly bad. They will probably be at different heights. I am guessing it is not bled right or it is the master.
Old 08-16-2006   #24
Onefast99gsx
Re: I give up...
Master = me too. When I changed all that crap on my 99, it was the master that created the problem in the first place. They relatively easy to change. Just a bitch getting under the dash. I took seat out to make it easier.
My problem was stated clearly in this link
http://www.roadraceengineering.com/c...ywheeltech.htm
A bad master cyl can definately give the appearance of a bad pressure plate.
Old 08-16-2006   #25
s1ngletracker
Drives: A BMW
Re: I give up...
yes, but he's saying it looks like the release fork is pivoting all the way. If he's right, then it couldnt be a clutch master or slave. Although "pivoting all the way" can be kinda hard to tell.
what you should do is measure the amount of travel that your slave cylinder piston is getting, and have someone else on here with a good functioning 2g (is that possible? ) do the same and see if you're actually getting enough travel out of it.
That will tell you if its in your hydraulic system or in your transmission itself somewhere.
Old 08-16-2006   #26
Re: I give up...
The pressure plate looks ok, they are not at different heights, i checked that, the fingers look a little scratched.
I know the system is bled properly, we did at least 10-15 sets of three pumps. Also sidenote: When we were bleeding the clutch, a friend would push the clutch down, i would then open the valve, then close the valve and my friend would have to pull up on the clutch to make it suck more fluid. Should you have to pull the clutch up by hand or should it be able to suck it up by itself?
The reason i am thinking pressure plate, is the LOUD SCREECH, when i push in the clutch, it sounds like metal on metal coming together.
Old 08-16-2006   #27
s1ngletracker
Drives: A BMW
Re: I give up...
most of hte time you have to pull it up. That's fine. Just as long as it still bounces back after you've bled it and tightened everything up.
Old 08-16-2006   #28
Re: I give up...
Quote from the RRE link...
"When the transmission is first installed in the car and just bolted down to the motor, this is the time to check the wear on the arm and ball. Checking it right that moment will save hours of hassle later! Look at where the arm protrudes out through the square boot on the front lower bell housing. With the arm pushed over towards the passenger side so that the release bearing is just touching the clutch, the arm should be either in the center of the square hole or towards the driver's side of center line.
If the arm is sitting off towards the passenger side, you need to pull the transmission back out and add a washer or two. This gets things back in line. If you don't, the hydraulics in trying to take up all the extra slack, will push the arm over and bottom out on the inner bell housing. If you are fighting clutch adjustment problems on an existing clutch install, get under the car and check this out. If you remove a crossmember to see it better, you can pull off the rubber boot and look in the bell housing with a flash light while an assistant pushes on the clutch pedal. You may see the arm hitting the inner bell housing."
I am going to check this when i get home tonight. I believe its settled towards the passenger side, where it shouldnt be. Hell maybe it is the throwout bearing afterall....
Old 08-16-2006   #29
s1ngletracker
Drives: A BMW
Re: I give up...
ding ding ding
oh, thats talking about the clutch pivot ball and arm, not the throwout bearing.
Old 08-16-2006   #30
Re: I give up...
Just wish i didnt have to take out the damn tranny to replace it.
Old 08-16-2006   #31
s1ngletracker
Drives: A BMW
Re: I give up...
well i'd inspect it first and make sure that the arm is angled wrong before you go pulling the tranny.
Old 08-16-2006   #32
Re: I give up...
Ill take a picture tonight and see what you guys think.
Old 08-16-2006   #33
npaulseth
Re: I give up...
Shoulda stuck with the auto.....
J/K, good luck fixing it. We all know how frustrating cars can be. Hang in there!
Old 08-16-2006   #34
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: I give up...
LOL DITTO!
- Josh L.P.
Old 08-16-2006   #35
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: I give up...
Originally Posted by s1ngletracker
wait.. .this is a 6 bolt isnt it? Nevermind my comment about crankwalk
Just because its a 6 bolt doesnt mean it cant get crankwalk.
I'd try the washers behind the pivot ball idea first, then if that doesnt work, then look into a new pressure plate/TOB. If the problem is still there I'd check for CW.
Originally Posted by shoutbox
Old 08-16-2006   #36
Re: I give up...
Does it screech bad if you push in the clutch with the car not running? If it only does it with the clutch running, then it is probably the throw out bearing.
Old 08-16-2006   #37
Re: I give up...
Yeah it only screeches when the car is running. And i just looked at where the position of the TOB fork is and its well over on the passenger side. Its funny because i had come to the conclusion that it wasnt because the inside of it was able to spin freely, and thats all the hayes manual told me to check. Doh.
Oh well, i have the next two days to do this so im pretty good.
Old 08-16-2006   #38
Nash
Nash's Avatar
Re: I give up...
Might as well get a new PP too. I had a problem with my old GST were the PP looked fine until I got the new and compared them. The old one you could tell was bad then, all the fingres were bent in evenly.
Old 08-17-2006   #39
Re: I give up...
No harm in replacing everything, at least that way you know everything is perfect and done correctly. Eventually you'll have to replace everything so you might as well do it all in one shot to save on your labor.
Old 08-17-2006   #40
Re: I give up...
I have also had a pressure plate problem before and I couldn't tell it was bad until I compared it to one that I knew was good.
