Old 08-21-2006   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Head Gasket Material Removal??
Does anyone know of the best and safest way to remove all of the lead like substance off of a head that has just been taken off? Also does it have to be completely removed and shiny or just almost all of it so that the surfaces are flat to the touch? Also I ordered a wiseco multi layer head gasket and is there anything i should know when putting it on?? Thanks for the help in advance.
Old 08-21-2006   #2
Re: Head Gasket Material Removal??
Wiseco manufacturers a headgasket?
Old 08-21-2006   #3
They resell Cometics.
Old 08-21-2006   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
That doesnt help me. Do you have any tricks??
Old 08-21-2006   #5
b00stcreep21
I hate everyone
b00stcreep21's Avatar
razor blade usually does the trick for me. make sure to try and get as little material to fall into the oil/water passages as possible. not too hard, just take your time
Old 08-21-2006   #6
Kougar
Drives: 06 RSX
Use a razer blade, a gasket scraper, and/or a 'wizzy wheel'
Get it as cleaned up as you can. Just remember it's your car, you want to half ass it, or make sure it's 100%?
Old 08-21-2006   #7
95talonracer
Finally Tuned...
Drives: Spyder GSX
If you scrape all of it off that you can, can it still look like there is shit on there but it seems to be just stained in a sence. I scraped all of it that i can tell and it is perfectly smooth. Also anything special that i should do with the new layer gasket? copper spray or anything??
Old 08-21-2006   #8
Razor blade then a scotch brite pad. Be careful with the head if you are doing that too, use a plastic putty knife, then carefully the scotch brite.
