Old 08-21-2006   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
1g 2g swap electrical ??
I am almost complete with my 1g 2g swap to go into the car but had a few final questions. I have a 95 tsi and am putting in a 91 complete motor and head. I have not touched the CAS at all on the 91 motor. What steps do i take on this since the vfaq was a bit too much at once on this subject. What wiring do i do and since i didnt touch the CAS i dont need to redo the timing do i? Let me know what you think.
Old 08-21-2006   #2
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: 1g 2g swap electrical ??
Also i am assuming that if i run the 1g plug setup that i still need to switch the plug wires and injector pinouts right?
Old 08-21-2006   #3
blageo23
AWD4G64
blageo23's Avatar
The CAS you take the blue wire from the crank angle sensor on the 2G and wire it with the 3 wires for the stock 2g CAS to the 1G CAS. I havent heard anything about the injectors but I know you need to do the plugs. Go to magnusmotorsports.com they have a nice wiring diagram for ya.
Old 08-21-2006   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
And i dont think ill have to mess with resetting the timing The way that they explain to do?
