Old 09-03-2006   #1
ARP headstud question
I forgot, do I put lube on the threads that go into the block (yes, I already retapped the holes)?
Old 09-03-2006   #2
Re: ARP headstud question
No. You put them in the block dry, and the lube on the end that the nuts go on.
Old 09-03-2006   #3
Thanks! I fingered them into the block dry, I thought they had to be fingered in there very gently when they are dry. LMAO. hahaha ishh.
Old 09-04-2006   #4
We had a big thread on this a while back. Some of us like to loc-tite the studs into the head. I have had several back out on me.
Old 09-05-2006   #5
I tighten the studs into the block, then lube the threads and the bottom of the nut.
Old 09-05-2006   #6
I do remember reading that thread when it was current. Hopefully I won't have any issues without the loc tite
Old 09-05-2006   #7
ARP says to put lube on the threads that go into the block also.
Old 09-06-2006   #8
Where in the hell do they say that?
It has always been top of threads, top of washer, bottom of nut.
ARP's in dry to block, no oil, no arp lube, no thread locker, DRY. But then again, I've probably only installed a few dozen sets without problems.
Old 09-06-2006   #9
On some cars you have to put thread sealer on them because the stud holes are open to coolant, but never lube. I Loctited the ones in my car in, but I also keep mine slightly off of bottomed out so there isn't any weird stress on the stud from it touching the bottom of the hole unevenly.
Old 09-06-2006   #10
Good point, some cars need some rtv/sealer due to the studs going into a coolant passage.
