Old 09-06-2006   #21
Re: How to make a Quick 14B Car?
Originally Posted by JET
Just get the turbo ported. Much easier and cheaper.
Hey what would you use to port it, carbide bits, grinding stones, sanding rolls? Could you use Carbide bits with a dremel? Or would something like that be better suited to an air-powered grinder?
Old 09-06-2006   #22
Gravy
Who's this guy?
After just finishing a porting job myself, GET A DAMN CARBIDE BIT!!!! I did a stock 1g mani and wish i hadn't been cheap. I got the carbide bit on the last night of porting. Cut the time in half, easy. Use the carbide to take out larger pieces of the metal and get the areas ground down, then use a stone to smoth them out. Follow up with some sand paper to get it nice and smooth and your all set.
Old 09-07-2006   #23
Where did you get your bit(s), and how much? I know carbide isnt cheap lol.
Old 09-08-2006   #24
Gravy
Who's this guy?
I know you can get a set of 3 of them from Sears for about $30 bucks, i opted out and got a single bit for $6 due to the lack of ever needing htem again, and being broke.
Old 09-08-2006   #25
tim
tim's Avatar
Harbor Freight or similar is the best place to get them. Sears does have them but they arent cheap and they are the same quality.
Old 09-09-2006   #26
I have a 3" gm maf, and maft. I'm still worried about fuel cut. What are my options? get DSMLink and STFU? A lot of people have been suggesting I go with a 2G MAF. I know some people say the MAFT is a POS, and would rather have a 2G mas. What are your opinions on the 2G MAF vs 3" GM/MAFt?
Old 09-09-2006   #27
AEM EMS
-A. Swift
Old 09-09-2006   #28
i've never hit fuel cut with the maft. isnt one of the switches in the control box a fuel cut toggle? its been awhile since i opened it up.
a 2g maf is fine as long as your power goals are in the low-mid 400s.
Old 09-10-2006   #29
tim
tim's Avatar
Originally Posted by Swifty1638
AEM EMS
-A. Swift
Funny you say that.
Do you feel right tuning and setting AEM up all on your own? Or, since you know people that can help you, you feel right recommending it?
Dont get me wrong, AEM is obvioulsy the way to go if you have either A. Have the knowledge to do it, or B. Have the money to make it happen with the help of someone like Shane or Josh or whoever that has worked with it extensively(sp?)
Old 09-10-2006   #30
Lol swifty, I know AEM is bomb shit, but I'm not gonna need that for awhile, if ever. Look at Vassil, he ran 10's with DSMLink, so I definately don't see it as a limiting factor. And plus, I'd rather have DSMlink because it's way more user friendly, and I could actually tune it myself, and learn a lot in the process.
Old 09-11-2006   #31
DSMLink is almost always the best choice.
Old 09-24-2006   #32
dumb_ricer
Hates Everything
Drives: Neon
Yeah, DSMLink is the way to go.
Only thing that really pisses me off about it is you cant use a MAP sensor with it. Gay Gay Gay.
420A > LS1 > All Else
I > All else
Old 09-25-2006   #33
You can use a MAP sensor with DSMLink. It has a speed density mode that ignores the MAF and uses a VE table.
Old 09-25-2006   #34
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
13.4 @103 here. Not much done.
Stock non eprom ecu
Stock injectors
Unported 14b
3" turbo back, cat less
Unported 2g o2 housing
3" intake pipe
Dejon Tool UICP
K&N filter.
Walbro 190
EVOIII Manifold
Ebay boost controller
ACT 2600 w/ street disk.
Race gas @19psi.
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
Old 09-25-2006   #35
Stock non eprom ecu
Stock injectors
Unported 14b
3" intake pipe
Dejon Tool UICP
K&N filter.
Walbro 190
EVOIII Manifold
Race gas @19psi.
Cool! I'm expecting a phone call from Shep any day now... And then I can work on making my car faster. List of my mods so far:
2g exhaust manifold
Shepherd Racing Stage 3 transmission rebuild
ACT 2600lb clutch with sprung 6 puck ceramic disk
ACT XACT flywheel
Ksport coilovers - 36way adj, full threaded body, front camber plates
Ingalls Engineering Rear adjustable rear control arms
Prothane motor mounts
Goodridge SS brake lines
Suspension Techniques front and rear sway bars
Symbroski Shifter bushings
Shifter bearings
OEM Heavy leather shift knob
Short throw Shifter
Buschur Racing 3" SS downpipe, testpipe, catback
No A/C
No Emissions
Buschur Racing cold air intake w/ K&N cone filter
MAF Translator v2.02
3" GM MAF
91 EPROM ECU
ARP Headstuds
Copper sprayed OEM headgasket
Elite Autosports manual boost controller
Tons of preventive maintenance stuff!
My car has been on stands since after the cookout (that same day lol). It was 100% stock then. I'd still like to get an FMIC, a fuel pump, and port/ceramic coat all the cast iron parts.
Old 09-25-2006   #36
turbo2086
turbo2086's Avatar
Ya I got some suspension work done too. As well as a lot of preventive maintence. Cause I didn't know if the previous owner did them or not, so just got them done anyways when I bought the car.
Setup looks solid.
Is this your red car? Or did you get another one. I remember you leaving me a message in cardomain, awhile back, saying how you really loved my car cause it was black, or something like that. lol
Old 09-26-2006   #37
I sold the 20G red car (my avatar pic) and got a 100% stock burgundy one (lol not anymore).
Old 09-26-2006   #38
haha damn I'm running out of money
Old 09-28-2006   #39
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Just to add to this, I am going to run my 14b to the limit
Mods are (well, some assebly is still going on)
Dejon Exaust 2.5" - 3.0"
2g O2 housing
Evo 3 ported exaust manifold
The turbo and the O2 housing are going to get ported on friday!
also have a 255hp fuel pump
AFPR to go with that also
I have the 2g mas, not installed yet because I need:
550cc
S-AFC
and a 4 bolt rear end after I break the 3 bolt!
What are the limits of this little turbo for psi? 16-18?
Was going to try to have it ready by dyno days but with a limited budget i don't think I am going to make it in time. Would be interesting to see what it would make on this little turbo.
Old 09-28-2006   #40
get a fmic too buddy, that sidemount will get HOT.
