Old 09-09-2006   #1
eclipse_spyder
The most ricest dsm
2.4l???
ok so im still a noob about dsm's. what does it mean when the say its a 2.4 liter stroker??? did they just put in the crankshaft stroker kit in the 2.0 block? or did they change the block too?
eclipse_spyder is offline   Reply With Quote
Old 09-09-2006   #2
iceminion
iceminion's Avatar
Re: 2.4l???
using the 2.0 block you can put a "stroker" crank kit in it to achieve 2.3 or 2.4L displacement. this = $$$$$$.
But 9 times out of 10 they are talking about the 4g64. (same as g4cs)
The process involves finding a 91 hunday sonata, taking the motor.
Using only the block and the crank from the hunday, add all of the stuff from your 2.0 (head, water pump, oil squirters, oil pan, timing junk, etc...) to the 2.4.
TAADAAAAA!! you have a 2.4 monster motor. (you will also NEEEEEED new pistons)
Seems complicated, but its totally worth it, I shall have on sooner or later.
building a 3000GT AWD Turbo.
Old 09-09-2006   #3
Re: 2.4l???
There are MANY cars you can find a 6bolt 4G64. I see one or two just sitting in junkyards all the time. As he said, most of the time when someone is talking about the "2.4L" they mean they have a 2.4L block from one of mnay non-turbo cars. Then you put in low compression pistons, and the DOHC turbo head bolts right on, as well as pretty much everything else. So, you basically "swap blocks" to get a .4L increase in displacement. And with our little 4 bangers, every little increase helps!
Old 09-09-2006   #4
Re: 2.4l???
Adds 50 hp & 70 lb/ft
Old 09-09-2006   #5
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Re: 2.4l???
You shoudeve researched about 2.4 litter swap in the search section of forums, but minion pretty much cleared it up for you.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 09-09-2006   #6
eclipse_spyder
The most ricest dsm
Re: 2.4l???
thanks for the helpful info guys. now i want that block. if you guys know anyone with one for sale, lmk.
Old 09-09-2006   #7
eclipse_spyder
The most ricest dsm
Re: 2.4l???
well i couldnt really find any info...but now i know
Old 09-09-2006   #8
eclipse_spyder
The most ricest dsm
Re: 2.4l???
"you will also NEEEEEED new pistons"
for this, will any of the aftermarket eclipse pistons fit in it like ross pistons or other brand?
Old 09-09-2006   #9
eclipse_spyder
The most ricest dsm
Re: 2.4l???
also is a 4g64 block only from spyder's? can you just put a 1g turbo head on it?
Old 09-10-2006   #10
iceminion
iceminion's Avatar
Re: 2.4l???
Spyders have a 7 bolt motor......people usually dont upgrade those. I am not saying it cannot be done, I am just suggesting that you go 6 bolt.
4g64 usually means 7 bolt.
g4cs usually means 6 bolt.
Old 09-10-2006   #11
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: 2.4l???
4G64 from the mini-vans.....Find the 6-bolt one.
Old 09-10-2006   #12
eclipse_spyder
The most ricest dsm
Re: 2.4l???
which cars did the 4g64's come in....i did some researchs and they said the older galants and expo's has them. which one would be the best ones?
Old 09-10-2006   #13
Re: 2.4l???
Chevy Malibus, Dodge Rams, and John Deere 8530 tractors.
Old 09-14-2006   #14
mike55112
mike55112's Avatar
Drives: 04 evo
Re: 2.4l???
I know that you can get a 4g64 block from pretty much any junk yard for cheap!
Old 09-14-2006   #15
mike55112
mike55112's Avatar
Drives: 04 evo
Re: 2.4l???
Or you can spend more money and get a fully built one!
Old 09-14-2006   #16
Re: 2.4l???
Does your Eclipse Spyder have the 2.4l in it already or do you have a turbo motor? I kinda like the 7-bolt 2.4ls, especially with all the 6-bolt 2.4l crank failures.
Old 09-14-2006   #17
Re: 2.4l???
The 6 bolt 46g4's are most commonly found in the 89-91 Hyundai Sonata's. There are a few other colt's, minivans, and other passanger cars that contained both the 6 and 7 bolt flavors.
Old 09-15-2006   #18
Gravy
Who's this guy?
Re: 2.4l???
Correct me if i'm wrong, but don't all 4g64's have the right block to do so? If so, i've got 3 of them in the local junk yards in the form of 6 bolt Mighty Max engines.
Also, for the 2.3 stroker, isn't it the 4g63 block with a different crank in it? Or was i reading something while drunk?
Old 09-15-2006   #19
tim
tim's Avatar
Re: 2.4l???
2.3l is the 4G63 with a different crank, correct.
I thought Mighty Maxs used the Starquest engine though? Maybe I am wrong?
Old 09-15-2006   #20
Re: 2.4l???
Only a few of the 2.4's out of various cars will bolt up to our trannies. That's why the Hyundai one is popular. I'm definitely a big fan, I love mine.
