Old 10-14-2006   #1
tjg
Transmission wont go into reverse
Ok i have a problem with my 96 talon tsi awd manual i just got a remanufactered transmission from mitsubishi graveyard and i put it in like a week ago. Everything did work fine but now i have some trouble with the reverse it doesnt have it it doesnt even fell like theres a slot for it. I was driving earlyer yesterday and i backed out of my driveway and it was fine parked it and it didnt have reverse anymore, plus my fifth gear only stays in if i'm on the gas if i let go of the gas it pops out. Please give me some info on how to fix this beast, i really like driving it but it just wants to keep crapping on me.
tjg is offline   Reply With Quote
Old 10-14-2006   #2
Bode
Bode's Avatar
Drives: 01 Impala
Re: Transmission wont go into reverse
Did you re adjust your clutch peddle? If your clutch does not fully disengage, it will not let you into reverse. Also, try putting it into 1st gear first then reverse.
Old 10-14-2006   #3
tjg
My clutch is really touchy, it engauges right when you let your foot off the petal. O and now my fifth gear is completely gone since i let my brother drive it, all you hear is grinding, this is what he said (Its fast but your fifth gear dont work.)
Old 10-15-2006   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Like Bode said, first, try adjusting the master cylinder rod on the clutch pedal. I believe you adjust it out if it's grabbing too close to the floor. Then come back and tell us your findings.
Old 10-15-2006   #5
tjg
Well i adjusted it and it did nothing got anymore ideas guys, i'm begining to think this tranny is not a rebuilt and its shit.
Old 10-15-2006   #6
5th gear popping out is a transmission assembly issue. There is a nut that holds the gear stacks together, that backed off.
Not even feeling the reverse slot is usually an assembly issue. The bolt that holds the reverse gear "assembly" in place could be missing or backed off as well.
99% of the time those 2 problems are transmission assembly issues. Clutch adjustment issues effect ALL gears, not just reverse.
Old 10-15-2006   #7
tjg
So are the nuts your talking about the ones on the outside like it you took off the cover plate just tight those bolts?
Old 10-15-2006   #8
Take off the end cover, there are 2 36?mm nuts. Those are suspose to be tightened and then "dented" so they don't back off.
Old 10-15-2006   #9
tim
tim's Avatar
Just curious what your "rebuild" consisted of? Also, was it a fresh rebuild or was it a used tranny that had been rebuilt at one time?
I googled mitsubishi graveyard and didnt see anything on their site regarding rebuilding services.
Old 10-15-2006   #10
tjg
This tranny was on there ebay store they say they take them apart and replace any worn parts gaskets, seals, bearings, gears, syncros and such. You can tell its been apart it has liquid gasket maker for the case seals, and the drive shaft seals are new.
Old 10-16-2006   #11
I already went through this once, exactly how you are describing.
The problems with having no reverse and no 5th sounds like you damaged the tranny, the causes for the damaged tranny are due to one or more of the items below. I damaged my tranny because of these things, hope it helps you.
Things to Check/replace:
VERY FIRST THING. Turn your adjustment screw on the peddle so to the right if your looking at the master cylender part of the screw, or the left if your facing the peddle. make sure it is almost all the way out. Do not take this step lightly, make sure you dont just skim over this because this can save you a shit load of a headache.Then try shifting it.
Go under the transmission where the slave cylender and make sure that the throwout bearing fork is either in the center, or towards the driver side. If its towards the passenger side then you either have a problem with the pressure plate, the clutch, or the shift fork, either way your taking out the tranny.
IF you are gonna take out the tranny check the clutch disk. Mine was destroyed. Check the pressure plate and the pivot ball. you might as well replace the throwout bearing just to be safe (and save a headache later on.
MAKE SURE the bolts that hold the tranny to the block are all very tight, especially the one that is just above the half shafts. (I had this problem, the bolt kept vibrating out and would cause the clutch not to shift due to the pressure plate pushing the tranny away from the motor. ) Make sure that this part of the tranny has no gap. it should be pressed up against the motor, This bolt is the only one that goes from the motor to the tranny, (as opposed to the bolts that go from the tranny to the motor)
Check these things and im sure you will find one of them problematic.
Old 10-16-2006   #12
Not nessesarily. When my bolts kept coming loose it affected reverse more then any other gear. DRASTICALLY. It would go into first and any other gear, (with little grind) but reverse was horrible.
He also said that the clutch engages right off the floor which is a tell tale sign of loose bolts or clutch adjustment.
Old 10-16-2006   #13
tjg
What loose bolts? all are tight and i adjusted the clutch it didnt do anything for me.
Old 10-16-2006   #14
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Make sure the crush washer is there.
Old 10-16-2006   #15
tjg
I did for the reverse switch it was there, shortly after looking at that the reverse didnt work.
Old 10-31-2006   #16
tjg
Well i did what you said i tightend the two bolts, they were loose alittle the middle one more than any, but there was no difference still no 5th just grinds and reverse is still locked out. Any ideas?
Old 10-31-2006   #17
How is the shift movement? Do you have full range on the shifter assembly?
Old 10-31-2006   #18
Outlaw1
Resident Redneck
Outlaw1's Avatar
Holy shit! That's a good post from Tom! WTF? You used punctuation, grammar and everything. Ok, your spelling still kinda sucks, but I'm very impressed.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 10-31-2006   #19
tjg
I got full range 1 thru 5th but reverse is locked out wich i really would like fixed i still drive the car every day with just 4 gears, 5th on the shifter locks in but theres nuthing there, i was thinking i could just pull the 5th gear, gear set off and put the one off of my bad transmission, on my bad tranny the intermediate gear shaft the bearings went out and it wore away some stuff and busted the case. Do you think i should try the 5th gear set swap?
Old 11-01-2006   #20
Bode
Bode's Avatar
Drives: 01 Impala
Taking apart a transmition and putting it back together right is not an easy task. I would not recommend it unless you seriously know what you are doing, and have the right tools to do it.
