Old 12-01-2006   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
sway bars
Well I've been thinking about getting lower sway bars for my 98 gsx. I have read that rear sway bars are very helpful, but are the fronts necessarily worth the money? like these bad boys are pricey and I was wondering if I should get the front and rears for like $300 or just the rears for like half that? And if anybody knows where I can get a cheaper set lemmy know!
pics or gtfo
Old 12-01-2006   #2
Re: sway bars
Get the front/rear set of RM bars, my friend put them on his '98 GSX and it was a huge improvement. Search around a bit, we had a huge swaybar thread just a few months ago.
Old 12-01-2006   #4
HiImBrian
HiImBrian's Avatar
Re: sway bars
Thanks, I found that thread and I think I might just go with the rear sway bar for now. I'm in the process of getting all my fuel mods on and then I'll need a tune, so that'll cost a buck or two.
pics or gtfo
Old 12-01-2006   #5
HiImBrian
HiImBrian's Avatar
Re: sway bars
Will I still need sway bar links if I get sway bars?
pics or gtfo
Old 12-01-2006   #6
rst95eclipse
Re: sway bars
Yes. Aftermarket sway bar kits do not come with end links. I've searched this issue since I had to cut my endlinks off. Let's just say that they cost a pretty penny. If you find a kit that does come with the endlinks.........please please please let me know of it.
Old 12-01-2006   #7
HiImBrian
HiImBrian's Avatar
Re: sway bars
Well the thing is, my links are off right now because of some suspension work I did a while back. So will I have to buy a set of links and put them on as well as the sway bars themselves?
pics or gtfo
Old 12-01-2006   #8
rst95eclipse
Re: sway bars
I don't know how your sway bar is going to work unless you install the endlinks as well. If your question is if you need new end links - you shouldn't as long as you can still install them (torque them to specs).
My problem was that the metal was so corroded and fatigued when I put my 14mm open between the rubber caps and started to wrench off the nut - the area that the 14mm was on stripped.
Old 12-01-2006   #9
Re: sway bars
Aftermarket anti-swaybars are a great upgrade for even stock suspension DSM's. I am glad to see more and more DSMers finally getting into handling.
Old 12-01-2006   #10
Re: sway bars
They have upper sway bars?
Old 12-01-2006   #11
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
Re: sway bars
owned!
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 12-01-2006   #12
HiImBrian
HiImBrian's Avatar
Re: sway bars
Many people confuse sway bars with strut bars. Just trying to be specific
pics or gtfo
Old 12-01-2006   #13
rst95eclipse
Re: sway bars
I agree with you completely. But it's definately not the first suspension mod that one should do. After a lowering kit and strut bars, it would be my next choice. But I would buy up a brake kit before some sway bars.
