Old 12-23-2006   #1
ExTREME
ExTREME's Avatar
Help meh please.
When I'm driving at low speeds it seems to studder, and/or bog down. Then when I get on the gas a bit it seems to bog then go up. Also, when I'm idling if I rev it up a little bit it seems to bog then go up and then when I let off the throttle it drops way down and almost dies. I don't sit there and wrap the piss out of it to sound cool, I just did it to test it out and it does almost die and it seems to pause. Is this a spark problem? Fuel pressure? Vaccum leak?
Thanks
-SA
Old 12-23-2006   #2
Re: Help meh please.
i would say maybe boost leak/exhaust leak.
.02 cents
Old 12-23-2006   #3
+1 for the boost leak test.
Old 12-23-2006   #4
What are you running for plugs and wires?
Old 12-23-2006   #5
ExTREME
ExTREME's Avatar
Ran the wrong plugs for a day, (BPR8ES). Not too sure how I aquired them but they were in there. Swapped them to BPR6es and some 8mm Accel wires. Going to order some 7mm NGK wires. Looking for a deal on them today, I'm at work and searching for a deal, I need to save my money to fix other things.
Old 12-23-2006   #6
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Doesnt sound like a plug issue, but check all the gaps on the plugs and wires just to be safe. I would go with the crowd on this one, check for a boost leak.
Old 12-23-2006   #7
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Also, the thought of a fuel issues isnt a bad one, but usually a fuel issue will worsen as the RPM goes up. You need more fuel as the load increases up the powerband.
Old 12-23-2006   #8
BPR7ES is your friend if you are running more than stock levels for boost.
Old 12-26-2006   #9
Jacek
Captain J-Sack
Check your timing,i gnition and belt.
Old 01-17-2007   #10
ExTREME
ExTREME's Avatar
It was a bad leak from the Stock 1g mani. to the 02 housing. I could see the exhaust in the morning when starting it up coming through where the gasket is. I tightened it up a bit, fixed it. +1 for leak test!
Thank you everyone who helped!
Problem Solved
Old 01-17-2007   #11
Congrats, good driving to ya!!
