Old 02-15-2007   #1
gsxer
regular 16g to a evoIII 16g..
Well, I have a regular or small 16g in my gsx and was wondering if I changed turbo to a EVOIII 16g would it make more power or would I not feel much change?
gsxer is offline   Reply With Quote
Old 02-16-2007   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: regular 16g to a evoIII 16g..
I'd only make more power if u were able to up your boost more. I dont think its worth it.
pics or gtfo
Old 02-16-2007   #3
Don't bother unless your regular 16G is in need of replacement and you're happy with the amount of power you're currently making. The EVOIII will make more power at the same boost level, but it won't be a whole lot.
Old 02-16-2007   #4
gsxer
ok so what about if i got a 20g? would that be better? or would a 50 trim?
Old 02-16-2007   #5
20G > 50-trim
Old 02-16-2007   #6
gsxer
so a 20g?? would be better?
Old 02-16-2007   #7
They're fairly equal. I like 20g's because they are OEM made by mitsu, and just seem to last a long time. But if you want to keep it simple and use an internal gate, well then you'll have a rather hard time finding a 20g internally gated.
Old 02-17-2007   #8
HiImBrian
HiImBrian's Avatar
Bigger turbos just mean u run lower boost. You have to upgrade injectors before you upgrade a turbo.
pics or gtfo
Old 02-17-2007   #9
What are your other mods? I would recommend either a 20g or 50 trim. I had a 50 trim PTE and loved it. Great match for the 2.0 on a daily driver. A 20g is basically the same size.
Old 02-17-2007   #10
gsxer
My mods are,
6-bolt motor swap w/
-arp hardware
-QPR EGR Block-off
-BS elim kit
-'90 oil filter housing
-small 16g
fmic
walboro 255
650cc injectors
polyeurethane motor mounts
ported 2g exhaust manifold
apexi n1 catback
Buschur TB elbow
2.5" downpipe, w/ dual 3" resonators, no cat
Apexi AFC-2 (getting DSMlink)
polished 1g rail with custom mounted FP gauge
10mm plug wires
RRE crankcase breather'/oil catch can
Joe P MBC
dual 12" Fal high flow fan(pull)
10" SPAL High flow fan (push)
polished ebay strut bar
Old 02-17-2007   #11
Either turbo would be fine. Like I said above, I do like the 20g's, but you pretty much have no choice but to run an external gate. The 50trims have the option of going internal if you want to keep it simple.
With that being said, I personally run a internally gate PTE 50trim. I enjoy it.
Old 02-18-2007   #12
gsxer
ok sounds good so 50 trims are winning write now huh. which one gives more power 50 or 20g? which one is easier to tune?
Old 02-18-2007   #13
50 trim will theoretically yield a bit more power, it is rated at 49lbs/min and the 20G is rated at 44lbs/min. Both should be about the same for tuning, but you will probably be able to run a little more boost on the 50-trim on pump gas.
Old 02-18-2007   #14
gsxer
Alright thanks sheides.
Old 02-18-2007   #15
Shane55113
Now 20% less Racist
Shane55113's Avatar
Evo3 16g is rated at 42lbs/min
