Go Back   MitsuStyle > Hosted Support Forums > JET's Customs
Old 10-23-2003   #1
A little background, I have been a machinist for 9 years making anything from tractor parts to heart pumps. I do my work at the machine shop after hours, so it is top notch. I guarantee all of my work 100%.
Porting:
Turbo- Fix boost creep $35
Turbo- Full port $50
Exhaust manifold $60
O2 housing $50
Turbo, manifold and O2 for $140
Stage I head porting with valves out $80
I can also do custom machining, we have a lathe and mill with digital readout. I also have access to a 220v MIG welder and a plasma cutter. My shop charge is $18-$25/hr depending on the job (includes everything but metal). I can do anything from taking out broken bolts to doing one off custom machining.
Old 10-23-2003   #2
john
Business as usual
john's Avatar
I was wondering how long it would take this forum to be used. You should talk to awd1dr if you haven't already.
97 Viper GTS
Old 10-24-2003   #3
Do you have any examples of any "high end" machining that you've done on a mill that you could maybe post some pictures of?
Old 10-25-2003   #4
redline
redline's Avatar
Drives: GSX
i just found out a few bolts loosend up in my exhaust housing and decided to snap. was curious if you could drill and tap the housing and maybe do a flapper upgrade.
redline is offline   Reply With Quote
Old 10-26-2003   #5
That would be no problem. Shoot me a PM and we can work out the details.
Old 11-15-2003   #6
ACRucrazy
Great prices!
Slow stuff
Old 11-15-2003   #7
How about a billet 70 mm throttle body?
Old 11-25-2003   #8
Sorry Steve, didn't see that post. We don't have a CNC at the moment, so that won't be possible.
I am looking into boring out stock throttle bodies to 64mm+. I don't know how big I can go. 66mm would be ideal for 2.5" IC piping. I will do a mock up in Solidworks and have it do all of the calculations for me. I hope to get to this some time in Dec.
Old 12-23-2003   #9
Here is a pic of some porting I did for a member. It looks much better in person, but you get the idea. Sorry for the size!!
Old 12-23-2003   #10
Jana
Mazda Bitch
oooooh shiny Looks like good work JET!
Old 12-24-2003   #11
on the right side you bored it out so much that the flange crack shows? is that sealed form the outside or....
Old 12-24-2003   #12
What kind of time-frame are we looking at if I bring you a 20G? It is already partially ported so it just needs to basically be hogged out.
Old 12-24-2003   #13
If you have looked at the inside of a mitsu turbo you will know that there is a step inside the inlet. That is just the remnants of the step. It is still over 3/8" thick there, so it is nowhere near coming out the side of the turbo.
Chris- If we set everything up I could have it done the same day. It would be the next evening at the latest.
Old 01-23-2004   #14
I have an update with some more work that I have done. This is going on one of our members' car. It is a new aluminum intake manifold flange that I made. The rest of the manifold is being made by QPR.
Old 01-27-2004   #15
Jet,
Can you do Tubular Exhuast manifolds?
I have an Archer SS that needs to be fixed. Raptor mentioned that the reason it cracks is because they used 2 different kinds of metal material and tried to weld them together? So basically what I would need would be a Head to manifold flange made and welded to the normal ss manifold tubes. Along with a flange to turbo.
-brian
Old 01-27-2004   #16
The really big thing with the Archer ones was that the tubes are thin and they did not stress relieve them. Stress relief is a HUGE thing, especially on something like that. As far as I know, none of the mass manufacturers do that (SFP included). There probably is not a lot of hope for the Archer.
Old 02-18-2004   #17
dumb_ricer
Hates Everything
Drives: Neon
How much would this cost?
My stock throttle body is 52mm that necks to 48mm and the plate is 52mm. A lot of the neon guys have said that you can get the stock throttle body to 55mm with proper machining and a throttle plate. How much do you think it would cost to get it all bored to 55mm and a throttle plate that is 55mm diameter to fit in perfectly? Any possible amount? 25bux or so?
420A > LS1 > All Else
I > All else
Old 02-19-2004   #18
Archer has devised a way to fix their cracking manifolds. I have seen a few of the reworked ones and they add a nice brace. Brian, contact Jeremy at Archer and tell him your situation, he should be able to work something out with you.
Old 02-19-2004   #19
It would probably cost at least $25 just for me to have the throttle plate made. It must be laser cut or water jetted. RRE charges $250. I want to look into it and see if I could do it for $150.
Old 04-22-2004   #20
joem
Drives: 1991 Talon awd auto
JET ported my 14b and it just ROCKS. 14b with a 3'' turbo back exhaust (with 3" O2 housing) and 0 creep. It used to creep to 23 psi by 4500 rpm. Stock flapper just a kick ass port job.
If you want it done right the first time give it to JET.
Thanks again
Joe
