Old 05-20-2007   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
So I'm thinking about a twin turbo setup... Opinions?
So I think I want to run twin turbos... I have NAWZ, but I need help deciding! Any opinions?
Originally Posted by shoutbox
Old 05-20-2007   #2
Re: So I'm thinking about a twin turbo setup... Opinions?
Hey, why not!!!
Old 05-20-2007   #3
is that a mechanical fuel pump I spy? Nice!
-A. Swift
Old 05-20-2007   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yup... Ran it last year on my Talon and worked pretty well. Had a friend machine me a flange (pictured) to mount a small pulley to the crank and it turned out very good.
I am going to get both of the stock fuel rails annodized, they are plenty big to run methanol on... I'll throw up a list of everything after a bit.
Old 05-20-2007   #5
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Ok Jake that's not fair! You can't have two turbos and nawzzzzz. You gotta give me one of the three!
pics or gtfo
Old 05-20-2007   #6
I think he's kidding on the turbos. Twins doesn't make any sense on a 4-banger.
Don't forget the collapsible passenger floor pan.
Old 05-20-2007   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Damn Steve! I forgot about that. Gotta get that overnighted from Japan!
Yes I'm kidding.
Turbo on the left is a GT4718 (aka GT4788 or T88), turbo on the right is a GT4202
Kinda up in the air which one to use, I might put the T88 on just to see how long it will actually take me to spool the god damn thing. But thats also what the nitrous is for. I do like the fact that at 3 bar the turbo's efficentcy is right at 100lbs/min.
Old 05-21-2007   #8
HiImBrian
HiImBrian's Avatar
I know hes kidding, but it's not fair to have two cars with turbos that big. The rules say you can only have one.
pics or gtfo
Old 05-21-2007   #9
Real Men use Thumpers.
http://www.turboneticsinc.com/turbo_thumper.htm
Old 05-21-2007   #10
If I remember right, Aerocomp used a T88 on a 2.0 and ran low 9's with just a few passes, can't remember if they used NAWZ at all. A 2.14L with a 150-shot and a 10K launch should get you down the track in a hurry.
Old 05-21-2007   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I know... I got it because it was a very good deal and I couldnt pass it up. I'm going to put it on just to see how it actually does, most likely I will be pulling it and putting the 4202 back on.
Old 05-21-2007   #12
Didn't Jesus have a T88 on his car? I think spool was 7k or something like that. I know there was a video of the car at night somewhere.
Old 05-21-2007   #13
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Mod list:
Engine
Ross pistons .040 - 10.5:1 C/R
Magnus Billet Rods
Knife Edged Crank
O-Ringed block
ACL Bearings
HKS 280 cams
HKS Cam gears
Beehive Springs
OEM Valves
3g lifters
ARP Studs
OEM Head gasket
Fuel/Intake/Exhaust/Turbo/MISC
8 - PTE 1600cc injectors
Aeromotive Mechanical Fuel pump + filter
Aeromotive AFPR
Twin rails
10 AN feed - 6AN Return
AEM injector driver box
AEM EMS
JMFab intake manifold
Q45 90mm TB
DNP Exhaust manifold
Tial 38mm WG
Tial 50mm BOV
Ebay FMIC
GT4718 or GT4202
NOS direct port
AEM Wideband
AEM CDI + COP setup
AEM 5 bar MAP
AEM IAT
More to come when I think of what I missed.
Old 05-21-2007   #14
There is a HUGE difference between a Greddy T88 and a Garrett T88. I assume Jesus had a Greddy T88 on his Eclipse, since he had one on his Supra too.
Old 05-21-2007   #15
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yes... His was a Greddy T88.
This one is pretty damn big for a 4 cylinder but I would just like to see how it does. From what I know and have "heard" it is similar to Rau's old turbo before he went smaller.
I like the 4202 a lot and the plan is to run that but it wont hurt anything to try this.
Old 05-21-2007   #16
Rau's current 80mm turbo spools at about my revlimiter.
Old 05-21-2007   #17
HiImBrian
HiImBrian's Avatar
Turbo lag ftw! hahaha
pics or gtfo
Old 05-22-2007   #18
The 4788 is a realy big turbo, even for a supra. I would think based on the ARP head studs and headgasket choice you might want to try the 4202 and keep the boost low. Its kind of cool that the "4788" looks not to much bigger then the 4202, just get a GT5591.5 and call it good.
Old 05-22-2007   #19
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I ran 42psi last year on the 42 with ARP's and the OEM head gasket with no o-ring. Never saw any problems.
If I could find some A1's I would be happy, but right now I do not have any. So there for they are not on my modification list.
I know Marco had a few sets awhile back, maybe I should get in touch with him again and see if he received and still has a set in stock.
Old 05-22-2007   #20
JamieSophia14
JamieSophia14's Avatar
what did you run last time you ran this, jw.
JamieSophia14 is offline   Reply With Quote
