Old 06-09-2007   #21
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: Need help, misfiring and dying
Originally Posted by BLaCk_1cE View Post
Alright after doing the plug wire test, All wires were giving off spark, but 2 of them, the 2 coming from the right tower side, are not sparking as much as the others were, so yeah. As for gas on cylinder, how would i go about diagnosing and fixing it? Does anyone recommend i take it to a mechanic/shop?
did you use a spark tester or just put the plug wires close to the head or a piece of metal? Because that really hurts the ignition coil if you dont use a tester.
Old 06-09-2007   #22
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
I just let it arc onto the head. But the car still started and drove after I did that test, like probably 4 dys ago i did that test. It drove thursday night even, got home, and came back 3 hours and it wouldnt start.
Old 06-15-2007   #23
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
well thank god she is runnin normal again (for now anyway). Turns out the long connector from the fuel rail to connect into the ecu or battery was barely even plugged in. Also, I had a bad wire, which i didnt even suspect, becuase I bought brand new ones... Well, guess they can be bought faulty out of the box, im proof. Thanks for everyones help!
